Old 02-06-2017, 05:28 PM   #1
soilent
Drives: 2022 BRZ Premium
Long term CNT header users, how is it?
I'm now on the search for a cost effective UEL. The CNT seems very intriguing, especially at the price point. Initial reviews seem to be positive, but what about some people who have used them long term? Let's say a year or longer. How has it been?
Does anyone think there's a better header for the money? Like something under $400? Or is worth it to just bite the bullet and spend the extra money on a Gruppe-S?
Thanks.
soilent is offline   Reply With Quote
Old 02-06-2017, 05:32 PM   #2
bababooey
Drives: BRZ SWP Limited -6MT
satisfied for about 15k miles worth. granted i havent put the car back in the air to check welds but id assume they are okay because its not making funny noises. for my money i couldnt have found a better deal. others may disagree.
Old 02-07-2017, 12:27 AM   #3
DAEMANO
Time Traveller
Had mine on for 10k+ miles and it was great. Removed it to get some work done on the car. No complaints.
Old 02-10-2017, 12:25 PM   #4
sirsol66
Drives: 2013 FRS- Hot Lava
I'm curious, what tune do you guys run with the CNT? I was planning to run an off the shelf openflash tune but wanted to make sure its safe enough for it (no knock). Anyone have data logs?
sirsol66 is offline   Reply With Quote
Old 02-10-2017, 04:59 PM   #5
bababooey
stage 2 ots (non ofh specific)
both about a month ago, maybe about 55 degrees out, clear skies.
http://www.datazap.me/u/n8brz/log-14...a=1-5-12-13-14
^ cruising in traffic, varying loads/engine speeds - for some reason advance mult was @ 93%
http://www.datazap.me/u/n8brz/log-14...data=1-5-12-13
^two full throttle pulls from 2nd about an hour later than previous. adv multiplier is solid. i still get a bit of that flkc from 5-7 and then shifting gears it remains. from previous response to these charts i believe my afr could be a lil better. im not confident enuff to optimize those spots out. i believe the critical values are mostly okay.?...
http://www.datazap.me/u/n8brz/log-14...=0&data=1-5-13
^ for comparison's sake, this was the ofh optimized stage 2 ots tune. these were 3rd gear pulls i believe. the flkc was still there, but youll see a bit of knock corrections. im not sure if that is too much to worry about.?..
this last one was also middle of summer like 95 deg. no telling if that has huge affect on the outcome of the readings other than air intake temp
Old 02-13-2017, 07:00 PM   #6
cawith
Drives: Toyota GT86 6M/T
Mine had cracked in a bend after about a year. Might actually have happened a while before I found out, but there were no obvious indications.
Anyway, I put the stock back on because I'm now supercharged :P
cawith is offline   Reply With Quote
Long Term FR-S regal Scion FR-S / Toyota 86 GT86 General Forum 83 04-01-2016 06:40 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 08:56 AM
Long term Bt216 Scion FR-S / Toyota 86 GT86 General Forum 3 06-06-2013 11:58 PM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
