Old 01-30-2017, 12:44 PM   #1
Lorico
Drives: 2015 FRS
RR racing BBK - 4 pistons
Does anyone own this set? http://www.rr-racing.com/RR-Racing-F...gt86fbk005.htm. Is this a direct bolt on? unlike the Wilwood set that is missing 4 bolts
really good price $795
Lorico is offline   Reply With Quote
Old 01-30-2017, 12:59 PM   #2
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
http://www.ft86club.com/forums/showthread.php?t=90379
Cockatoo is offline   Reply With Quote
Old 01-30-2017, 01:20 PM   #3
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
In response to your question, I have that exact kit and yes, it is direct bolt in. Install took me and my friend around 6 hours but much of that was us figuring out how to install it (we haven't done anything beyond oil/pad/fluid changes before) and fighting rusted bolts (Winter driven Canadian car, moderate rust) for the brake lines.
I think someone who is more experienced working on cars and doesn't have to fight with as much rust as us should be able to get through this job in about 2 hours.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
Lorico (01-30-2017)
Old 01-30-2017, 03:43 PM   #4
ryoma
ryoma's Avatar
just make sure that you download the brake template and test fit it with your wheels prior to hitting the buy button
The Following User Says Thank You to ryoma For This Useful Post:
Lorico (01-30-2017)
Old 01-30-2017, 05:14 PM   #5
frslee
Just drive it
Drives: 13' FR-S
@Lorico FYI those calipers won't clear stock wheels. I inserted total of 13mm spacers (10mm + 3mm). Otherwise, it bolts right in and great value for the money.
frslee is offline   Reply With Quote
The Following User Says Thank You to frslee For This Useful Post:
Lorico (01-30-2017)
Old 01-30-2017, 07:58 PM   #6
Lorico
Drives: 2015 FRS
Perfect. I own and will probably track my xxr 527. They're 18x8.75. So I'm almost positive they would fit.
Thanks guys!
Old 01-30-2017, 09:17 PM   #7
8R6
8R6's Avatar
Drives: FRS
Thanks guys!
your wheel offset is just as important as the wheel width. and you really want to track on those heavy wheels? you'd be better off tracking stock wheels with spacers (if you're going to be running this brake kit).
8R6 is offline   Reply With Quote
Old 01-30-2017, 09:45 PM   #8
n0thing
Drives: Subaru BRZ
how is it holding up in winter?
n0thing is offline   Reply With Quote
Old 01-30-2017, 10:26 PM   #9
Lynxis
Lynxis's Avatar
At this point, I don't really want to pass judgement. They work and the rotor and caliper look good from the outside but my brakes are pulsing and because it's the dead of winter here, I haven't been able to diagnose the problem yet. It could be related to salt/corrosion or it could be something else. I'll have a good look once it warms up in the spring and I'll properly diagnose the problem and post my findings when I do it. I'll take some pictures too
Old 01-31-2017, 02:55 AM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Seriously? The RR thread linked in the first response to you is on the front page of this section...
8R6 (02-08-2017)
Ej25 pistons? ChandlerSwyng Other Vehicles & General Automotive Discussions 2 06-19-2014 01:46 PM
13.5:1 Pistons woode Forced Induction 13 04-27-2014 11:06 PM
MMMMMM....forged pistons jadewbj Forced Induction 23 10-08-2012 06:46 PM
CP Pistons for FA20 MattR Engine, Exhaust, Transmission 1 10-04-2012 07:22 PM
