bullshit roads, low hanging single exhaust and coilovers
title says it all, I'm fortunate to live in speedbump/pothole central, and I am gonna put coilovers on my car, that's just a foregone conclusion either way. fuck the consequences.
now, handful of issues. my greddy revolution RS is only hanging about 3-4 inches above the ground as it is with stock ride height. no idea how much further down I can go without tearing the whole thing off at the next speedbump. now, question is, and I've googled around and all I've gotten out of it is one guy claiming that bilstein B14 can go even higher than stock height. which coilovers out there can at the very least match, or at least come close to the stock ride height? I've never had coilovers on a car before, and I'd rather not be stuck with a set of coilovers set that can't be adjusted higher from a, say, 20mm standard drop. Idea is basically that I can at least try and gradually lower the car from its standard ride height, and try it out from there. and it has to be TUV certified, be glad you don't live in Norway. EDIT: Currently looking at H&R monotube, KW V1 and the B14 as they've got TUV certification. greatly appreciate if any owners could give me a quick run down or other recommendations. Last edited by balci; 01-29-2017 at 05:12 PM. Reason: stuff |
Drives: frs
Totalled
I feel sorry for you... lol. gl
not playing cards
Go the other direction.
might have exegeratted a bit on the horrible roads, but they're far from nice. and our speedbumps are basically just square slabs of concrete placed at random everywhere.
anyone with any TUV certified coilovers that are able to match the original ride height? |
Drives: 15 BRZ LTD, 05 FXT
Buy the coilovers you want, add 1" lift spacers from ADF, and adjust height to please.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
imo Bilstein will be the highest quality, I had mine setup for a half inch lower than stock (~12mm) iirc, I didn't try going higher but it's likely possible.
But this begs the question, why are you getting coilovers? |
#10 |
not playing cards
Fixed. Thanks for the heads-up.
#11 | |
with a coilover zeroing at stock height, I have the ability to lower it as much as I can, even if its just 15mm, or just return it back to standard. |
#12 |
Potato Farmer
Drives: #SLOBRZ
If you want to get hardcore, install some Parts Shop Max diff/Subframe risers, they will lift the diff up 40mm, then get some of their flat exhaust tubing and get an exhaust shop to modify your exhaust..
All the clearance!
Something something butter..
www.vic86brzclub.com |
| Greddy Supreme SP Exhaust & Revolution RS Single Exhaust | Evasive Motorsports | Groupbuys | 119 | 01-31-2017 01:53 PM |
| Is this bullshit? | SquadRon | Off-Topic Lounge [WARNING: NO POLITICS] | 101 | 06-16-2016 11:19 AM |
| WTB:TRD Exhaust, Hampton Roads Area | 2FAST2FRS | Want-To-Buy Requests | 0 | 03-25-2016 08:43 PM |
| Exhaust hole cover for Single tip exhaust - Innovated Dynamics | Kostamojen | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 06-09-2015 10:45 PM |
| Another project teaser. Exhaust hole covers for single exit exhaust! | Wonderbar | Cosmetic Modification (Interior/Exterior/Lighting) | 57 | 05-30-2014 01:46 AM |
