Old 01-28-2017, 01:21 PM   #1
Teseo
Drives: frs
Installing wheels, soon...
Im going to install a set of avid av20 (17x8 +35) on stock suspension atm and i want to know if possible, what other things needed? Camber bolts for front? Lug nuts? Wheel spacer? Long studs (thats what she daid)... i want everything sorted out to get it in one shot. Depending how it looks i will add RCE yellows down the road. Also i played with fitment calc, and seems everything is fine but with 1" of flush (good for me)
Old 01-28-2017, 01:29 PM   #2
swarb
You are good, that is a great setup. Inside clearance is roughly same as stock, and outside clearance you are 1 inch further out. Now comes the hard part on deciding what tire and what size. Camber bolts aren't needed but are highly suggested.
The Following User Says Thank You to swarb For This Useful Post:
Teseo (01-28-2017)
Old 01-28-2017, 01:44 PM   #3
Teseo
Drives: frs
Going to run hankook ventus evo 2 v12 on stock specs until wear down, probably going hankook rs3 or bridgestone potenza on 225 or try and error which one fit until rub. Any suggestions will be apreciate, thanks mate
Edit: ordered whiteline camber bolts.
Old 01-28-2017, 02:07 PM   #4
swarb
Why not go 225/45 straight out? Adding 1" of wheel width, why not 10mm of tire width? (stock tires are on the narrow side though) You are no where near rubbing and could fit a 245/40.
Teseo (01-28-2017)
Old 01-28-2017, 02:23 PM   #5
Teseo
Drives: frs
Wow 245!! Stock tires will look like donuts in comparision, lets see what can do my local tire shop
Old 01-30-2017, 05:04 AM   #6
tyler_win_photo
tyler_win_photo's Avatar
Probably better to go 225 if you want to avoid stretch
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
Teseo (01-30-2017)
Installing 18" wheels with spacers? Need advice? donjrian Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-15-2016 11:51 AM
Installing ID injectors mrk1 Forced Induction 7 09-05-2014 09:17 AM
Should I dyno tests after installing lighter wheels? makesdrivingfunagain Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 06-10-2014 04:17 PM
installing this weekend! MObrz5 Northern California 3 04-17-2014 08:06 PM
need help installing this chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-14-2013 01:17 PM
