Drives: Sterling BRZ Ltd
Installing ID injectors
To anyone else who has installed ID injectors, did you find them to be about 1/2" taller then the stockers? A spacer and longer bolts really are easy but I just wanted to make sure I wasn't shipped the wrong parts. PN on the box checks out.
Off Topic
You need a rubber mallet to properly seat them.
p.s., don't do this. |
Hot Lava 6MT
Drives: Hot Lava FR-S
1/2" nylon spacers, I think u can get them at home depot plus you'll need longer m8x1.25 bolts
too soon jr
Drives: 2014 Sterling Silver BRZ Limited
If they are ID725's or ID1000's then you will need spacers. The other sizes will not require them.
T1 Race Development
ID Injector Dynamics |
nice, making spacers is no problem.
Off Topic
If you wanted to you could cut the mounting brackets in half and lengthen them.
Drives: 2014 SWP BRZ, MT
Yes I installed mine a week ago. They require 8mm (.315") tall spacers not 1/2" if you want to be precise
. The injector body is 48mm vs the OEM 40mm. I turned a couple of them out of some 5/8" aluminum stock I had lying around. You'll also need to pick up four 25mm long M8 x 1.25 bolts.Also make sure you take the old injector seals out of the intake manifold, I almost forgot myself. I only thought of this because you said it looked 1/2" high and those seals being in there with the added injector height would look about 1/2" Last edited by zkv476; 09-05-2014 at 09:27 AM. |
| E85 issues with injectors? | CaptainSlow | Software Tuning | 66 | 07-31-2016 10:47 AM |
| Injectors installation | kaybee123 | Forced Induction | 27 | 03-08-2016 09:26 PM |
| SprayItRacing (SiR) injectors | vgi | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 06-12-2014 09:12 AM |
| injectors and tuning? | love 4 boost | Software Tuning | 8 | 11-09-2013 07:56 AM |
