Old 01-26-2017, 05:43 PM   #1
cat94
Drives: '17 86
Jack stands help
Hello,
Does anyone have any experience with the Torin Aluminum Jack Stands? (https://www.amazon.com/Torin-T43004-...ct_top?ie=UTF8)
The reason why I'm thinking of getting a set of these is because I'm looking for a flat-top style jack stand.
I picked up a set of Harbor Freight jack stands and jack stand pads in an attempt to protect the paint on the pinch welds, but they ended up stripping more of the paint than if I had bare metal to metal contact. One of the pinch welds also has a slight bend to it (probably my fault). Does anyone have any advice on preventing pinch weld bending (specifically on flat-top stands)? I've since stopped caring so much about the paint, though will still paint over it occasionally with some ceramic paint or undercoating to prevent rust.
Also, it seems like the jack stand was partially/fully supported by the area just inside the pinch weld (what is that residue? seems like it was there to fill some holes/prevent scratching by the stock jack). I've seen mixed opinions on whether or not this is safe. It appears some people even go as far as turning their jack stands 90 degrees and supporting their cars with only that area.
cat94 is offline   Reply With Quote
Old 01-26-2017, 06:12 PM   #2
Ben_G
Drives: Blue BRZ
So here's my take on it. If you look at the factory emergency jack, the pinch weld is used ONLY to locate it inboard/outboard on the car. The jack itself doesn't even touch the pinchweld vertically. All the weight is supported by the pad just inside the pinch weld.
The pinch weld is used only because it's easier than trying to correctly position a jack/jack stand behind it.
I think that's the REAL jacking point, not the pinch weld. in fact, I believe this enough that i made this: Name:  2016-04-20 18.04.22.jpg
I don't recommend turning the jackstand sideways though....that's just asking for trouble when it slips off.
Ben_G is offline   Reply With Quote
Old 01-26-2017, 06:27 PM   #3
cat94
Drives: '17 86
I think that's the REAL jacking point, not the pinch weld. in fact, I believe this enough that i made this: Attachment 148748
Those look great. If only they made jack stands in that shape.
Do you place those on top of your jack stands and let friction keep them in place?
I know there are some adapters out there for the jack itself to lift from behind the pinch weld, but I'm skeptical on placing those on Y shaped jack stands.
Old 01-26-2017, 08:11 PM   #4
Ben_G
Drives: Blue BRZ
I'm actually one of those daredevils that don't use jackstands and just lift the car with the jack only..... =( but mostly because I only really do tire changes and not much more.
If I were to make these fit on a jack stand, I'd probably weld on some two inch skirts so that they won't slide/pop off the stand head?
Old 01-26-2017, 09:12 PM   #5
cat94
Drives: '17 86
I see, I wish I had some more tools to machine my own solution. Unfortunately, it would probably be cheaper to get a set of Esco jack stands ($50-70/ea?)
Old 01-26-2017, 09:59 PM   #6
Marat
Drives: '15 Ultramarine FR-S
Made these out of hockey pucks so I can protect my rockers.
Marat is offline   Reply With Quote
Old 01-27-2017, 11:38 AM   #7
bee-jay
bee-jay's Avatar
Drives: 2014 BRZ LTD WR Blue Pearl
https://smile.amazon.com/s/ref=nb_sb...=3E717NPQXVYN1
bee-jay is offline   Reply With Quote
Old 01-27-2017, 08:26 PM   #8
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
The Torins scare the weeee out of me. I ended up buying 4 ESCO stands.
https://www.amazon.com/ESCO-10498-Ja...co+jack+stands
They're rock steady, have a slotted rubber cushion over the top plate to protect the pinch welds and support 3 tons each. What's not to like?
Not cheap, but IMHO well worth it.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 01-27-2017, 08:40 PM   #9
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
I have the similar setup. Bought hockey pucks from dollar store and made these.
Sideways is offline   Reply With Quote
Old 01-28-2017, 03:06 AM   #10
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I second the ESCO stands. I bought four of them. A bit of an investment, but ABSOLUTELY worth it.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 01-28-2017, 04:29 AM   #11
Yardjass
Yardjass's Avatar
Drives: '14 Monogram, '95 Miata, '90 300ZX
Third vote for the ESCO stands. My Z has been sitting on them for the past month or so while I swap the engine and redo the undercoating, and I absolutely love them. They don't seem to adjust as low as a conventional jack stand but they go low enough for me.
Yardjass is offline   Reply With Quote
Old 01-28-2017, 11:28 PM   #12
track junkie
Drives: 2022 Subaru BRZ
The Esco jack stands, ESC-10498, I just received yesterday cost $133.15 for a set of four delivered.
That's $31.05 each and only $8.95 shipping for all four.
The company, link provided, is almost out of stock.
They seem to sell them fast at this price. This is the best price I have found.
It's an extremely strong jack stand. Extra safe!
Note the photo below is from the manufacturers website and is what I received.
The photo on coastal tool supply website, link below, shows the old model which had only 5 adjustable positions. They shipped me the current 10 adjustable position model.
http://www.coastaltoolsupply.com/product/ESC-10498.html
http://esco.net/products/esco-3-ton-...ce-jack-stand/
track junkie is offline   Reply With Quote
Old 01-30-2017, 01:46 PM   #13
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
what is jack stands? huh?
[/URL]
Old 01-30-2017, 02:14 PM   #14
jasonojordan
Drives: 2013 satin white brz limited
[/URL]
This is what I'd like to ultimately get.
jasonojordan is offline   Reply With Quote
Napa 3-ton Jack Stands phobos512 Miscellaneous 3 01-30-2016 11:10 AM
WTB: Low profile floor jack and jack stands! lupindub Want-To-Buy Requests 2 11-26-2015 11:03 PM
Japanese jack stands? Augora Scion FR-S / Toyota 86 GT86 General Forum 4 05-26-2014 12:59 PM
jack stands in the peninsula?? Shindig Northern California 2 04-28-2014 12:28 PM
ramps + jack stands so26 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 04-23-2013 04:43 PM
