| Engine Swaps Discussion of engine swaps. |
I need the tremec t56 magnum xl dimensions
So I'm trying to find an alternative trans for the vorshlag kit but I need to know the length from the end of the bell housing to the shifter. I also need to confirm that the shifter sits exactly center or if it's back an inch or forward an inch from center. I have a transmission in mind that may be direct fit but need dimensions to confirm.
Thanks guys!! |
#2 | |
Drives: 2015 Raven V8
But that is missing the size of the custom bell housing and input shaft.
But of course.
Thanks that should help.
Guest
Posts: n/a
T56 Magnum requires a shifter relocation kit to bring the shifter up in the stock location. It's approx 7" further forward than an F-Body/GTO T56 (which is a direct fit)
Guest
Posts: n/a
![]() ![]() T56 GTO vs Magnum Sent from my iPhone using Tapatalk |
Drives: 2013 Scion FR-S Series 10
Well the Magnum XL should be similar length to the GTO/F-Body transmission. The XL is an extended shifter version(direct shift) vs the original Magnum pictured above
Current Mods: Eibach Sportlines/ Borla UEL Header/ Invidia N1 Catback/ OFT Stage 2 UEL E85 Tune/ Enkei EDR9 18x7.5
Guest
Posts: n/a
![]() Got this from Vorschlag's site. Def looks like the shifter is closer to the right position. Sent from my iPhone using Tapatalk |
#10 | |
Officially it only comes for Ford but Vorshlag gets them special for GM. Might as well get XL if you're buying new rather than expensive shifter for regular Magnum. I'm curious what transmission the OP is thinking about. Maybe a 6060 with external shift linkages? |
#11 |
Drives: 2015 frs
I have the trans from vorshlag. Do you still need the measurements? I can get them posted tonight if so
#12 |
Guest
Posts: n/a
The only difference between the ford and gm transmissions are the types of sensors used, which are interchangeable and easily available.
#13 |
I purchased a F body T56 and will be getting an adapter plate for the shifter. I am trying to get a more costly option for the swap for anyone who doesn't want to pay the full retail price of the custom XL Magnum. I'm trying to keep the cost down and resale there in the event someone wants to part out or sell off.
#14 | |
| spitfire481's Precision 6766, sleeved block, color change, Tremec | spitfire481 | Member's Car Journals | 351 | 01-05-2018 02:56 PM |
| Aisin to Tremec | cf6mech | Engine, Exhaust, Transmission | 20 | 09-02-2017 12:33 AM |
| FS: aFe Magnum FLOW OER Pro DRY S filter | Erci | Engine, Exhaust, Bolt-Ons | 4 | 06-28-2016 06:46 PM |
| magnum mk | fatoni | Other Vehicles & General Automotive Discussions | 0 | 11-07-2013 01:13 AM |
| Aisin to Tremec | cf6mech | Engine, Exhaust, Transmission | 7 | 08-23-2013 11:07 AM |
