Old 08-12-2013, 05:38 AM   #1
cf6mech
Drives: FRS Silver LS1 swapped.
Aisin to Tremec
As this Tranny is only rated to 210ftlbs of torque,..there are options. I'm currently in contact with a Tremec rep who has already done many BRZ/FRS Aisin to Tremec conversions,...I like to build to strength and going to 210 to 700 suits me just fine,...it may even be a direct linkage and not a remote shifter.....even better.
Español Search
OverviewProductionQualityCorporateLocations
Driveline SystemsTechnologyEngineering ServicesComponentsMotor Sports & AftermarketOur CustomersFTP
Job OpportunitiesResume
NewsIndustry EventsMedia Gallery
Home > Products & Services > Motor Sports & Aftermarket > Products > Magnum XL
Magnum XL 6-Speed Transmission
Introduced to the marketplace in 2012, the Magnum XL is a continuation of the popular Magnum 6-speed series. Featuring all the most important content from the original Magnum, the XL retains its brute strength and sophistication, but eliminates its multiple shifter locations and dual speedo outputs.
Refinements include a new extended length tail section designed to eliminate the semi-remote shifter found in many popular late-model applications.
Initially available for the 2005 and up "S197" Mustang, the Magnum XL was designed specifically to replace the OEM 5 or 6 speed transmission where performance improvements are desired. Simplifying the swap, the Magnum XL includes a SFI-approved steel bellhousing, crossmember, trans mount isolated shifter and shift ball and even reuses the OEM hydraulic clutch relase system.
  • Trans mount isolated shifter and shift ball
  • 700 lb-ft torque capacity
  • Choice of two different gear ratio sets (2.66 or 2.97)
  • SFI-approved steel bellhousing
cf6mech is offline   Reply With Quote
Old 08-12-2013, 06:05 AM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Pricing on such thing ?
Not a huge mastermind on tremec gearboxes but all I know is that they make the t56 gearbox which is an amazing gearbox used for numerous cars and years.
I'd love a GETRAG gearbox but if a company comes out with a bolt on it that's going to be amazing
Gd luck with your build
Old 08-12-2013, 06:54 AM   #3
Dipstik-sportech
Dipstik-sportech's Avatar
I'll be honest my buddy has a 2010 Camaro ss with the Tremec 6060 6 speed. That thing shifts like my '79 Chevy truck. Shift throws are stupid long and forget about the precision feel of our cars. I know u need to sacrifice some things in the pursuit of strength but a v160 will do the same and they shift a hell of a lot nicer.
Old 08-12-2013, 07:11 AM   #4
SigmaHyperion
Drives: 2013 SWP BRZ Limited
That's just the shifting mechanism that GM uses. My GTO felt like rowing through the gears of a semi truck when i got it. Vague, rubbery, and throws measured in feet. A shifter from a racing team out of Australia fixed that. Wasnt cheap, but its the best shifter I've used in any vehicle.
SigmaHyperion is offline   Reply With Quote
Old 08-12-2013, 07:29 AM   #5
SmsAlSuwaidi
Boosted
V160 yummy GETRAG are the shit
Old 08-12-2013, 08:07 AM   #6
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
And that 700ft/lbs is rated for cars thats 1000lbs heavier.
Curious about price and how PnP this will be.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 08-23-2013, 11:00 AM   #7
Dustin@Dynosty
another tranny to look at is the 350z CD009 Trans, they can be had for much cheaper than the V160 and hold 1300whp (more than this chassis needs), we haven't had time or the need just yet to look into this but its on the long term to do list
Dustin@Dynosty is offline   Reply With Quote
Old 08-23-2013, 11:07 AM   #8
bakerr6
Drives: 2013 raven black fr-s
If you guys plan on developing a kit for this, I would be interested in 2-3 years. I like this trans in the way it shifts
bakerr6 is offline   Reply With Quote
Parts interchange with other Aisin AZ6 transmissions brn12345 Engine, Exhaust, Transmission 22 11-06-2012 11:19 AM
