Old 01-24-2017, 01:30 PM   #1
JDM4E
Drives: Honda Accord Euro
Aftermarket headers - vibration?
Just a question for all the people with aftermarket headers WITHOUT a flex joints. Do you noticed increased vibration from the exhaust to your car?
I would love to order with flex joints - only JDL did that but sadly they abandon the design and now everything is solid
And I red somewhere here that you get more vibrations but I cannot find it anymore.
Thanks
JDM4E is offline   Reply With Quote
Old 01-24-2017, 02:23 PM   #2
fika84
fika84's Avatar
No.
fika84 is offline   Reply With Quote
Old 01-24-2017, 02:24 PM   #3
swarb
I didn't notice it. Probably notice more from the sound/power than the vibration.
Old 01-24-2017, 02:27 PM   #4
Teseo
Drives: frs
Have JDL UEL, no vibration
Old 01-24-2017, 07:38 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
the problem with your question is that no one you're asking has the proper equipment to test for vibration, other than their own butts.
Old 01-24-2017, 08:48 PM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The problem with specifically isolating header vibration would be difficult as it's incredibly close to the engine, which is dampened by the motor mounts.
If aftermarket headers were causing enough vibration to be noticeable, you could try softer motor mounts, but that would have its negative impacts as well.
Old 01-25-2017, 03:16 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Flex-joints in aftermarket headers were there to compensate thermal expansion, not to add movement for some vibration dampening. And in some header models they were later on removed, or weren't designed in at all, when manufacturers found out that absence of them didn't increase noticeably cracking of welds.
Extra noises/exhaust loudness may come from cat removal or from thinner thickness tubes used in header, not from vibrations (unless header rubs somewhere on frame, and then vibrates together with engine it's hard mounted on. But flexjoints won't fix that).
Old 01-25-2017, 04:27 AM   #8
JDM4E
OK guys thank you very much to you all.
Old 01-25-2017, 05:01 AM   #9
steve99
If its vibrating is may be the header or overpipe hittingvonbskid plate , chassis or front stabiliser bar or mount
Old 01-25-2017, 05:02 AM   #10
mav1178
mav1178's Avatar
Hence my response.
If one is asking about in-cabin vibration, the average user can't differentiate between lack of flex joints vs. increased sound transmitted as vibration through the cabin.
Also, even if there were more vibration, the rest of the exhaust is on hangers. Many parts of this can't be answered without knowing what else is on the car.
I'm not one to normally give a vague answer, but the question needs to be narrowed down to give a better response. Just saying "no" isn't a complete answer, especially if OP is asking it in the context of vehicle longevity.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
cdrazic93 (01-26-2017)
Old 01-25-2017, 06:28 AM   #11
JDM4E
Now I am confused.
My question was about in cabin vibration - i.e. comfort. In other words - is there a difference in comfort caused by vibration if I have a header with flex joints vs. solid design?
The longevity is an issue for me too. My mind tells me that there is a reason why OEMs do this, even @JDLAutoDesign said when they had flex designs that they don't recommend solid headers on street cars. But now, including JDL, everybody is "flex joints is for nothing", and won't cause decreased comfort or longevity issues.
Old 01-25-2017, 11:14 AM   #12
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I get Mavs point but you are asking if it is noticeable to try and get a consensus to see if you might have a problem. I would say I do not notice any more and you should check clearances for the subframe, skid plate, etc
Old 01-25-2017, 11:41 AM   #13
JDM4E
I don't have a header yet, I am still deciding what to get.
Old 01-25-2017, 11:52 AM   #14
finch1750
finch1750's Avatar
Ahhh. Ok. Yeah, if people got serious vibration enough to notice just from feel it would be all over the forum. In terms of smaller vibratioms/longevtiy/etc who knows. Not many people have enough mileage to get a good amount of data even
Noticeable vibration after installing aftermarket parts. boredjester Engine, Exhaust, Transmission 14 09-28-2016 10:38 AM
Looking for any aftermarket headers Easy Mid-Atlantic 11 05-24-2015 08:36 PM
Aftermarket headers in Ontario Mr.Impreza CANADA 22 05-02-2015 11:42 AM
WTB aftermarket Headers Nitro_FRS Engine, Exhaust, Bolt-Ons 5 01-09-2014 02:07 AM
Is aftermarket UEL headers with a cat a bad idea? IAmNotTheDriftKing Engine, Exhaust, Transmission 27 12-27-2013 06:14 PM
