Old 08-21-2013, 11:44 AM   #1
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
Is aftermarket UEL headers with a cat a bad idea?
So I really want some UEL headers. Not only is there a performance gain over stock and ELs, they also sound amazing! Only one company makes UEL headers with a catalytic converter that I know of, which is FA20club. That made me excited. Then I read somewhere that this is a bad idea because it is just bound to break in a year or two. This doesn't make sense to me, the car already comes with UEL headers(atleast that is what i have heard) with cat, so why will aftermarket ones be a bad idea.
tldr: Is it true that buying aftermarket UEL headers a bad idea because something may break, or should everything be fine?
IAmNotTheDriftKing is offline   Reply With Quote
Old 08-21-2013, 11:47 AM   #2
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
The stock headers are equal length (almost).
A catted header is fine as long as you tune for it and don't run too lean and burn it out. It will make less power than a catless header, though. Also if you track the car often and in high ambient temps the cat in the header may fail prematurely.
I'd recommend JDL Auto Design's UEL header for their craftsmanship and lifetime warranty.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
FR-S Matt (12-27-2013), ngabdala (08-21-2013)
Old 08-21-2013, 11:49 AM   #3
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
EDIT: ATL BRZ beat me to it.
Does anyone know if you could ditch the header cat and instead install the sensor on the second one?
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
Old 08-21-2013, 11:51 AM   #4
ATL BRZ
ATL BRZ's Avatar
More trouble than it's worth.
Old 08-21-2013, 11:52 AM   #5
IAmNotTheDriftKing
Well I need to run a cat because my county is one of two counties in my state that does emissions. I know the FA20club headers also comes with a lifetime warranty but they aren't very pretty.
Do you know where I could get more info on a tune to work with a catted header?
I forgot to mention, I don't track my car but I do go autocrossing in it, which I don't think should be a problem.
Old 08-21-2013, 11:57 AM   #6
ATL BRZ
ATL BRZ's Avatar
If your state doesn't do visual inspections (like mine) then you can still pass emissions with a catless header. You just have to get rid of the CEL that will likely follow with either a secondary O2 sensor spacer or an ecu reflash (tune). Remember the car has a secondary cat in the front pipe and if there is no visual inspection then it's simply reading the OBD2 data coming from the car and if it's "reading" that the primary cat is present (even if it's not) then you're good to go.
Well if @FA20Club.com are making the catted uel headers, and they also sell tunes.....
The Following User Says Thank You to ATL BRZ For This Useful Post:
weepel (12-01-2014)
Old 08-21-2013, 12:26 PM   #7
sw20kosh
Drives: 2013 Black FR-S
FA20CLUB + their specific tune that they have created for it......
Old 08-21-2013, 12:57 PM   #8
Chee-Hu
Chee-Hu's Avatar
...Not only is there a performance gain over stock and ELs, ...
Source? I thought it was EL that made/make more hp than UEL from what I've gathered and read so far.
Chee-Hu is offline   Reply With Quote
The Following 4 Users Say Thank You to Chee-Hu For This Useful Post:
enjoi23 (08-21-2013), F1point4 (08-21-2013), ramiram1984 (12-27-2013), Turdinator (08-21-2013)
Old 08-21-2013, 01:05 PM   #9
bakerr6
Drives: 2013 raven black fr-s
ELs typically do make more power. FA20club headers could be just as "pretty" if they had a similar coating on them. I wouldn't buy based off looks though, but more or less quality
bakerr6 is offline   Reply With Quote
Old 08-21-2013, 01:10 PM   #10
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Yeah I thought that was weird as well, EL should make more power up top than UEL. If my memory serves me correctly, UEL makes more mid range power.
Old 08-21-2013, 01:13 PM   #11
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
You need an O2 spacer to prevent CEL if your state does not inspect the header visually.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 08-21-2013, 01:38 PM   #12
IAmNotTheDriftKing
FT86speedfactory put borla UELs and EL headers both with no cat. The uels made more power everywhere. Here is a picture.
The Following User Says Thank You to IAmNotTheDriftKing For This Useful Post:
flippy (08-21-2013)
Old 08-21-2013, 01:46 PM   #13
ATL BRZ
ATL BRZ's Avatar
I thought this thread was about cats in headers? Not starting yet another EL vs UEL debate...
The Following 3 Users Say Thank You to ATL BRZ For This Useful Post:
finch1750 (12-27-2013), Starscream15 (08-21-2013), stockysnail (08-22-2013)
Old 08-21-2013, 02:10 PM   #14
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 03:47 PM
225/45/18 Bad Idea? alex88 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 04-22-2014 11:25 AM
Is it a bad idea to run headers without a tune?? Mike86 Engine, Exhaust, Transmission 48 09-06-2013 03:31 PM
Any idea what this is? idreamofdrifting Scion FR-S / Toyota 86 GT86 General Forum 14 02-08-2013 10:50 PM
Best idea for a bed ever! dorifuto Off-Topic Lounge [WARNING: NO POLITICS] 9 11-19-2012 10:34 AM
