Old 01-19-2017, 08:58 PM   #1
Serphs
Drives: 2014 Raven Scion FR-S
Turbo help
Not sure if this topic belongs here or somewhere else, if so please place it in the correct section.
My buddy and i will be putting a turbo into his car in the next few months, he has a 2013 FR-S Automatic transmission. My FR-S is a manual and i'm not sure which turbo we should purchase for him. We were considering the Greddy 518v kit or the MAPperformance FA20 precision kit, but i realized a completely stock MANUAL FR-S might have clutch problems with either of these kits, so i'm not sure if they would be the best in an automatic.
If anyone could provide me with information on a decent working turbo kit for an automatic kit, it would be much appreciated.
Serphs is offline   Reply With Quote
Old 01-19-2017, 09:24 PM   #2
gillster91
Drives: 2014 frs
if you keep the torque low and under 300whp then you don't need a clutch
gillster91 is offline   Reply With Quote
Old 01-20-2017, 01:04 AM   #3
humfrz
My buddy and i will be putting a turbo into his car in the next few months, he has a 2013 FR-S Automatic transmission..... .
Hi Serphs and welcome to the forum.
The forum has a forced induction section that you may wish to check out ..... maybe ask over there ......
humfrz
Old 01-20-2017, 01:06 AM   #4
humfrz
????? ....... they are planning on putting the turbo in a car with a AT ..... at least, that's the way I read his post .....
humfrz
finch1750 (01-20-2017)
Old 01-20-2017, 09:03 PM   #5
tyler_win_photo
tyler_win_photo's Avatar
Personally I'm running 220 torque on an AT with a stage 2 avo turbo, it's been holding up well. I'm not sure what the max torque that would be reliable for an AT though.
tyler_win_photo is offline   Reply With Quote
Old 01-20-2017, 09:16 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
It should hold fine in terms of catastrophic failure from failure from what I have read. But from talking to a local tuner on FI cars that have AT the fluid is taking a beating from the extra heat which could lead to premature wear. I would ask in threads for each kit for AT guys and also talk to the companies themselves
Old 01-21-2017, 11:37 AM   #7
tyler_win_photo
Found some old threads for you.
http://www.ft86club.com/forums/showthread.php?t=18868
It states that the auto torque capacity is 300nm which equates to 220 ft lbs.
But here's some real world data
http://www.ft86club.com/forums/showthread.php?t=106593
There's a couple autos running 340 - 400 ft lbs reliably. I know AVO Japan has been testing an auto that runs around 260 ft lbs for quite a while now. I would probably stay under 260 ft lbs to keep it safe.
As mentioned above, the #1 killer of our transmissions is heat. It's best to get a transmission cooler and high temp auto transmission fluid if you plan on running the car hard for extended periods of time. Personally I run Redline D6.
Old 01-21-2017, 12:09 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yeah I run a turbo automatic FRS and so far so good. I love not losing boost between shifts :p
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
Bren5279's Full turbo partout (JDL uel turbo, Greddy Evo 3, AEM gauges, + More) VA bren5279 Engine, Exhaust, Bolt-Ons 69 06-29-2015 10:56 PM
Greddy turbo kit and AVO world turbo kit SPECIAL PRICING! THMotorsports.com Forced Induction 129 07-24-2014 06:51 PM
