Old 01-18-2017, 04:01 AM   #1
ejv_frs
ejv_frs's Avatar
Drives: Scion FRS
Sway Bars for Track
This is out of my norm first of all.
I have upgraded most of my suspension already but I have been holding off on doing my sway bars. I am building a track so I wanted what (mm) would be best
I know every driver has their preference but this is something I do not know much about.
ejv_frs is offline   Reply With Quote
Old 01-18-2017, 04:15 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Try asking here.
http://www.ft86club.com/forums/showthread.php?t=38926
And be prepared to give more detail about why you want sways
wparsons (01-18-2017)
Old 01-18-2017, 04:44 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
This.
Old 01-18-2017, 04:59 AM   #4
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Don't replace parts for the sake of replacing parts. It's a waste of time and money.
The Following 4 Users Say Thank You to EAGLE5 For This Useful Post:
LOLS2K (01-18-2017), soulreapersteve (01-18-2017), strat61caster (01-18-2017), wparsons (01-18-2017)
Old 01-18-2017, 06:20 AM   #5
Gunman
Drives: 2019 Mazda Miata RF
If you don't know exactly what you want, get adjustable ARB's, so you can tune the car to your liking.
Gunman is offline   Reply With Quote
Old 01-18-2017, 10:26 AM   #6
humfrz
Yep, as far as needing larger sway bars ...... it ain't a miata .....
humfrz
Old 01-18-2017, 11:23 AM   #7
EAGLE5
Dismember
EAGLE5's Avatar
Well, I could see putting a larger sway bar in the front... Reduce that 2013 FRS power-on oversteer. Or a thinner one in the rear.
Old 01-18-2017, 01:20 PM   #8
finch1750
finch1750's Avatar
A local norcal shop is testing one right now. Well it's still 14mm but adjustable. Stiffest is stock and it only gets softer. Saw it when I stopped by the other day.
EAGLE5 (01-18-2017)
Old 01-18-2017, 01:42 PM   #9
strat61caster
strat61caster's Avatar
ineedyourdiddly
Old 01-18-2017, 02:03 PM   #10
finch1750
finch1750's Avatar
They aren't a vendor on the forum, so be sure to follow the local Facebook group for product release since that's where they will blast it out once ready.
Old 01-18-2017, 02:25 PM   #11
Racecomp Engineering
It very much depends on the rest of your set-up and application.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 01-19-2017, 06:12 PM   #12
juliog
juliog's Avatar
Drives: 86
There is no "best". But the 13-16 cars all understeer (shocker!) in stock form, so a stiffer rear sway bar like the adjustable Eibach works well to take away rear grip and help the car rotate.
Downsides are a slightly harsher ride and less forgiving handling during transitions at very high speed.
But if you have to ask, then you shouldn't be looking at sway bars. Just keep driving and figure out what you want to improve or fix exactly.
juliog is offline   Reply With Quote
Old 01-20-2017, 01:31 AM   #13
EAGLE5
Dismember
EAGLE5's Avatar
Who cannot make a '13 FRS rotate? It understeers if you enter a corner too fast. On power, it happily oversteers all day long.
FR-S stock sway bars compared to TRD bars babydriver Scion FR-S / Toyota 86 GT86 General Forum 3 12-01-2014 09:12 PM
brz and fr-s sway bars different? 1010110 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-03-2013 01:43 AM
ST sway bars bmxhotsauce Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-09-2013 03:11 PM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 06:00 PM
