Drives: 2016 BRZ Limited
tom's tail lights usdm dot approved turn signal problem
anyone experiencing this problem? when i signal right and i make a right turn, when the turn signal stalk click back into its normal position, it triggers the left turn signal real quick. sometimes happens when i make a left turn and it triggers the right signal.
here's a quick video: https://drive.google.com/open?id=0Bx...m11UUtwMVNUTTQ |
Drives: 1980 corvette, 2014 Subaru BRZ
did you get a new steering wheel recently?
no sir, only thing i touched was changing out the relay in that area
Dismember
Drives: 2013 Red Scion FR-S
I'd contact the vendor or company and get a new relay.
| The Following User Says Thank You to EAGLE5 For This Useful Post: | ed_423 (01-19-2017) |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
Are you sure your turn signal stalk isn't overly sensitive? I noticed that it happens when I try cancelling a turn, it would snap past the "neutral" position and briefly trigger the other turn signal.
#6 | |
Is there a way to "fine tune" the sensitivity ? did you ever fix it or you just left it how it is? |
Incidentally, I always thought it was just the cheapness of the turn signal stalk that shot past the neutral state given the amount of pressure I applied to cancel a turn.
It's possible the stock incandescent turn signals need more time to "light up" compared to LED signals, which is why it doesn't happen. Just a guess. |
#8 | |
Drives: 2016 BRZ
I have the same lights and the same thing happens. Doesn't bother me though. It's more the turn signal stalk than the lights. |
| FS: TOMS Tail Lights - Red - USDM DOT Approved | Subscap | Exterior Parts (Aero, Lighting, Etc.) | 0 | 01-15-2017 02:10 PM |
| Problem with turn signal lights | coolaron | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 05-18-2015 12:11 AM |
| WTB: TOMS USDM DOT approved tail lights | the puppet master | Want-To-Buy Requests | 1 | 03-20-2015 06:45 AM |
| Tom's JDM/USDM DOT Approved Tail Lights ***Photos/DIY Video*** | FT-86 SpeedFactory | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 09-14-2013 05:47 PM |
| Tom's JDM/USDM DOT Approved Tail Lights ***Photos/DIY Video*** | FT-86 SpeedFactory | DIY (Do-It-Yourself) Guides | 0 | 09-13-2013 09:46 AM |
