Old 01-18-2017, 04:43 AM   #1
ed_423
ed_423's Avatar
Drives: 2016 BRZ Limited
tom's tail lights usdm dot approved turn signal problem
anyone experiencing this problem? when i signal right and i make a right turn, when the turn signal stalk click back into its normal position, it triggers the left turn signal real quick. sometimes happens when i make a left turn and it triggers the right signal.
here's a quick video:
https://drive.google.com/open?id=0Bx...m11UUtwMVNUTTQ
ed_423 is offline   Reply With Quote
Old 01-19-2017, 12:10 PM   #2
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
did you get a new steering wheel recently?
G-Man is offline   Reply With Quote
Old 01-19-2017, 03:29 PM   #3
ed_423
ed_423's Avatar
no sir, only thing i touched was changing out the relay in that area
Old 01-19-2017, 03:42 PM   #4
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I'd contact the vendor or company and get a new relay.
The Following User Says Thank You to EAGLE5 For This Useful Post:
ed_423 (01-19-2017)
Old 01-19-2017, 03:45 PM   #5
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Are you sure your turn signal stalk isn't overly sensitive? I noticed that it happens when I try cancelling a turn, it would snap past the "neutral" position and briefly trigger the other turn signal.
dhuang is offline   Reply With Quote
Old 01-19-2017, 04:40 PM   #6
ed_423
ed_423's Avatar
That's weird, because it wouldn't do that when it was OEM tail lights? and it only flashes the tom tail lights, and not the front turn signals.
Is there a way to "fine tune" the sensitivity ? did you ever fix it or you just left it how it is?
Old 01-19-2017, 05:09 PM   #7
dhuang
dhuang's Avatar
Incidentally, I always thought it was just the cheapness of the turn signal stalk that shot past the neutral state given the amount of pressure I applied to cancel a turn.
It's possible the stock incandescent turn signals need more time to "light up" compared to LED signals, which is why it doesn't happen. Just a guess.
Old 02-20-2017, 10:24 PM   #8
Joon525
Joon525's Avatar
Drives: 2016 BRZ
^This.
I have the same lights and the same thing happens. Doesn't bother me though. It's more the turn signal stalk than the lights.
Joon525 is offline   Reply With Quote
FS: TOMS Tail Lights - Red - USDM DOT Approved Subscap Exterior Parts (Aero, Lighting, Etc.) 0 01-15-2017 03:10 PM
Problem with turn signal lights coolaron Cosmetic Modification (Interior/Exterior/Lighting) 2 05-18-2015 01:11 AM
WTB: TOMS USDM DOT approved tail lights the puppet master Want-To-Buy Requests 1 03-20-2015 07:45 AM
Tom's JDM/USDM DOT Approved Tail Lights ***Photos/DIY Video*** FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 4 09-14-2013 06:47 PM
Tom's JDM/USDM DOT Approved Tail Lights ***Photos/DIY Video*** FT-86 SpeedFactory DIY (Do-It-Yourself) Guides 0 09-13-2013 10:46 AM
