Drives: 2017 Brz
widest and narrowest summer tires
So i got some rota titans 17x8 +45 and used the stock tires...wow, they look stretched!! Its stock suspension and settings so it really looks funny. Anyone know which stock size tires are actually wider than advertised? Or, which 245/40/17's run more narrow than usual? This is my daily so no race tires, but I'd like to at least get the tire to match the 8inch width without looking stretched.
go 225 wide
Undisputed El Presidente
Drives: Zenki 37J ZN6
Bridgestone S-04 ran wide from what I compared them to. A 225 would be good on there
Drives: Legacy GT
Go to tirerack and click on the specs tab of a tire, it shows the actual width. Any decent 225/45 is going to fit on there just fine and not be stretched.
| The Following User Says Thank You to jamal For This Useful Post: | why? (01-12-2017) |
Drives: 2015 Scion frz
245/40 Michelin pilot super sports run really narrow. Slight stretch on my 17x9 wheels. People say they fit more like a 225...
Drives: 2017 Brz
thanks guys, appreciate the help!
I thought about the 225/45 but the overall diam is more like half an inch more. My car isnt dropped so it might look like a lift than anything else
Drives: Legacy GT
225/45 is completely fine. 0.4" taller overall means 0.2" difference from hub to ground.
Only happy when it rains.
Drives: series.blue
every single tire manufacturer will list all the specs you need, including actual tire width on their website.
Country Boy 4 Life
I have ran both 225/45 and 245/40 Michelin tires. The difference in height is subtle. I wouldn't worry about it. Also, IcyBrzzz is correct. The 245/40 MPSS is narrower than some 245's. I went from a 245/40/17 MPSS to a 245/35/18 MPSS, the 18's tread width is half inch wider.
I LIKE TIRES! |
#10 |
Drives: Legacy GT
Personally I would try to avoid putting a 245 on an 8" rim, even though it has been done. Having the wheel slightly wider gives the tire casing better support.
Seriously, get yourself a good 225/45. The set will be like $100 cheaper than 245s and fit better on the wheels. |
#11 |
Drives: 2017 Brz
well, I've been eyeing the new Firehawk Indy 500 and theyre pretty inexpensive...in a 225/45. I'll probably get them when my OEM tires get worn down some more.
Thank you! |
#12 |
Drives: 2015 BRZ
sorry if this has been answered before, but would a 225/45 tire effect gearing since it is a taller tire? when you compare 245/40 to the stock tire its almost the same dimensions. just trying to get a better understanding. thanks
#13 | |
Little Member
Drives: Bloo - The 13' BRZ
Yes the 245/40 should match the overall diameter of the stock 215/45, but the extra width would be up to you whether you want that or not.
| The Following User Says Thank You to yelsew For This Useful Post: | Vital (01-13-2017) |
#14 |
Drives: 2017 Brz
The stocks look silly small on a 8inch wheel, and a 235 would be the right width but the diameter would be either way too big or too small depending if 45 or 40. :/ I'll be happy with a squared off profile instead of a stretched look...hence the looking for a super skinny 245/40 but the smallest i found had tread width of 8.5inches...so looks like 225/45 it is.
| Widest wheel on stock tires? | JW843 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 12-21-2015 05:13 PM |
| Widest Track tires for stock wheels?? | track_warrior | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 56 | 10-11-2015 11:01 AM |
| FS: OEM Tires used for 1 summer. | zex | Canada Classifieds | 7 | 11-22-2014 07:05 AM |
| widest possible tires | fish66 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 05-04-2013 01:41 PM |
| Yep, these are summer-only tires. | FRiSson | New England | 5 | 11-09-2012 09:12 AM |
