Old 01-06-2017, 09:47 PM   #1
Roneezy
Roneezy's Avatar
Drives: Scion FRS Halo White 2015
Switching from ST Coils to a more Comfortable Setup
Hey whats up friends,
I've honestly been looking up so much on these forums, facebook group, and any other place on google before I decided to post this but I really would like help.
Can I get some some recommendations for comfortable coilovers?
I currently have ST coilovers and after 6 months, I'd like to say I'm over them lol. I DD my FRS and am tired of the random clunks(yes I'm sure everything is tightened and what not) and awful ride comfort.
I have a few coilovers in mind such as Cusco Street Spec A(no mounts), Tein Flex Z, Greddy x KW, skunk2 Pro-C, etc.
Is there a way I can still drop the car 1.2-1.5 inches and still be comfortable? I don't track or do anything hard with the car, I just want to enjoy my daily commute without it being a pain.
Roneezy is offline   Reply With Quote
Old 01-06-2017, 09:52 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Idk, the ST coils are some of the softest on the market. And anything with camber plates is going to make more noise then ones that reuse the stock mounts since it replaces the rubber ones with all metal.
RSR Black i are meant for lowering and comfort but dont know if they will ride softer then ST
Old 01-06-2017, 09:52 PM   #3
shellslinger
Drives: Whiteout FRS
I've only had experience w/ the Tein Flex Z's and RSR Sports-I coilovers. The Flex Z's are pretty good for daily driving but over LA roads it can get pretty gnarly. My Sports-I on the other hand are lot more smoother and comfortable than the Flex Z's. I'm not a race car driver or really track my car at all but to me the Sports-I offer the comfort that is missing from the Flex Z's and a bit more performance than the Flex Z's.
I don't think you'll be disappointed with the Flex Z's.
shellslinger is offline   Reply With Quote
Old 01-06-2017, 09:56 PM   #4
Roneezy
Roneezy's Avatar
Yeah I had really wanted the Flex Zs back in July but they were sold out and vendors didn't get them until October-ish.
I'm tired of these crappy california roads! Lol
Old 01-06-2017, 10:06 PM   #5
ryoma
ryoma's Avatar
there's a guy in SoCal selling the RSR Sports-i for $500 used. check the local for sale thread.
Old 01-06-2017, 10:13 PM   #6
shellslinger
@Roneezy, pick'em up quick
Old 01-06-2017, 10:17 PM   #7
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Don't buy cheap coilovers. The drop you're after is minimal and easily achieved with most lowering springs - RSR and Swift come to mind, but there are countless others.
Trying to save money here is going to cost you more in the end. ^Those used coils will need to be rebuilt sooner than new coils. That typically costs $150/corner, and who knows when you'll need to do that (you cant verify their internal condition nor past use / abuse)... then factor in downtime for your car, install costs, and alignment costs. I've been down that road, and it's not fun.
Save your money and spend wisely the first time. I have RSR Sports-i and they're good... stock-ish until you hit a turn. Start with those and work UP in price range, not down. Good luck.
sdemo is offline   Reply With Quote
Old 01-06-2017, 10:52 PM   #8
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
You're not going to be able to drop 1.5" and still have comfort unless you can change the laws of physics. Coilovers were never really meant for street driving anyway. They can be a huge PITA and the only reason I use them is for AutoX and HPDE. If all you do is drive on the street, save yourself the headache and go back to shocks and springs.
smg1138 is offline   Reply With Quote
Old 01-06-2017, 11:06 PM   #9
wparsons
wparsons's Avatar
If comfort is top of your list, and you want to be ~1.25" lower, then get Ohlins. Cheap ones will always ride rougher due to lower quality shocks.
flickr
Old 01-06-2017, 11:58 PM   #10
strat61caster
strat61caster's Avatar
Maybe Bilstein B14's, made to reuse stock top hats, I only had them about 1/2" lower than stock and they rode very similar to OE, can't comment on how comfy they are when you go as low as you want, maybe someone else has done it before idk.
ineedyourdiddly
Old 01-07-2017, 12:00 AM   #11
jamal
jamal's Avatar
Drives: Legacy GT
The greddys are the same thing you have but with a rebound adjuster, and possibly stiffer springs.
Tein, cusco, skunk2, etc generally do not ride better than kw based stuff.
You want something that rides well, go with either struts/springs, which are usually softer, or the Bilstein B14.
Also, the lower you get, the less bump travel you have. So it has to be stiffer, or it will end up in the bump stops. Sometimes it is lower and stiffer and still in the stops.
jamal is offline   Reply With Quote
Old 01-07-2017, 12:06 AM   #12
sdemo
sdemo's Avatar
^ "Low" and "stiff" or "rough" are not explicit trade offs. Having less bump travel does not mean the car rides rough. Shock valving matters.
Old 01-07-2017, 12:33 AM   #13
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Absolutely true but one has to pay for quality damping. While the above mentioned dampers are of higher quality than the $600 Ebay specials they are still not what I would call great dampers. Everything's relative.
Old 01-07-2017, 01:11 AM   #14
jamal
jamal's Avatar
Drives: Legacy GT
I didn't say that. But with $1000 suspension it's generally the case. And you lower the suspension too far it doesn't matter what dampers you have- it's in the bump stops and has no travel.
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
most comfortable shock with Eibach Pro Kit Crashhollywood12 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 01-15-2016 12:01 PM
Which is the most comfortable coilover on brz/frs?? HowL Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 04-27-2015 08:02 AM
Stock Suspension comfortable? dannythetran Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 03-10-2015 07:17 AM
Lowering the car and a comfortable ride etherealfall Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 12-21-2014 03:03 AM
