Old 12-20-2014, 04:32 AM   #1
etherealfall
Drives: Toyota 86 GTS Storm Black
Lowering the car and a comfortable ride
Hello guys
I have a reasonably broad question but with a couple of specific goals in mind.
I'm hunting for a coil over set that is comfortable. Not soft. But looking for a set that doesn't bounce around a lot.
I don't have a specific budget but would rather not break the bank.
My goal is to lower the car to about 1 finger gap all around on 235/40/18 tyres and fitting 18x9.5+34.
Some questions:
- are there any coil overs that would provide a smoother ride relative to stock?
- will I need anything for the rear to adjust for the camber and toe?
Thanks in advance.
etherealfall is offline   Reply With Quote
Old 12-20-2014, 10:45 AM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
You can't reduce your travel by so much and expect to be as comfortable as stock. It's just impossible. Lower REQUIRES stiffer springs. There's no if, ands, or buts, unless you want to hit your bump stops on every penny. That would be even worse than a tiff ride.
And yes the rear will need either lower control arms or upper control arm camber bushing. The LCA's are the easier route.
Old 12-20-2014, 11:00 AM   #3
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
possible, but it requires realistic (stiff) spring rates, the right tire sizes, dampers with a lot more bump travel, and you're going to have to remove the wheel liners and possibly clearance the unibody inside the fenders.
if you want it to not ride like **** you want 2" or 3" of bump travel up from whatever you want the static ride height to be, so imagine your finger of wheelgap travelling 3" up into the fenders and that'll give you an idea of what you need to cut out.
IMO, do something custom-ish with bilsteins, or call somewhere like fortune and ask them for coilovers with relatively high spring rates (like 2k higher front and rear than they come stock), but valved for street driving. you'll need aftermarket LCA's to get enough bump travel in the rear for sure
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 12-20-2014, 11:10 AM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
Stiffer springs simply require very different valving; most cheap coilovers seem to have trouble with this.
For super low on a coilover that seems set up right (spring rate, valving) to handle it I've been seeing the RS*R Black-i recommended a fair amount lately.
Old 12-20-2014, 11:18 AM   #5
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
I know you mentioned "coilovers" but I've been running RS*R SuperDowns for a while now, and they are about perfect imo. The ride quality is almost on par with factory springs and I can barely get a finger in between the wheel gaps. As far as camber, I'm at -1.25 front with white line bolts and -2.2 rear with natural camber no adjustments. The springs obviously are stiffer than stock, so there is a tiny bit of bounce, but it's not bad. I'll put it this way, my wife didn't even notice a change in ride quality, and she would be the first to bitch about it!! This pic is right after I did the spring install, sorry for the shit quality..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 12-20-2014, 11:30 AM   #6
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Oddly, see my latest blog post on the B8 setup I'm using, might be worthwhile to you.
Eibach pro-kit, Bilstein B8's, front sway, roll center kit, end links = $1570. Much better than a just buying a budget coil over only and nothing else imo.
On 245/40/17 in this pic.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 12-21-2014, 12:20 AM   #7
etherealfall
I was looking at coilovers by Endless (Zeal) and was wondering how these would fare.
I've had them on my DC5 before after using Tein SuperStreets and the difference in comfort was night and day. I'm not after a soft ride but less of a clunky and 'bouncy' ride.
I had the Zeal Function X previously. I believe they have rebranded them a bit. I'm currently looking at the Zeal Function 7's with their springs set at 8kg/7kg i believe.
Does anyone have experience with Zeal with the ZN6 chassis?
Old 12-21-2014, 02:41 AM   #8
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
You know the size of your bank, we do not.
It has been said by knowledgeable people on these forums that one can have relatively high spring rates and comfortable ride but you have to pay for quality damping.
Old 12-21-2014, 02:45 AM   #9
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
Penske should get you what you want but you're looking in the neighborhood of 6k for shocks alone
Digitalanalog is offline   Reply With Quote
Old 12-21-2014, 02:54 AM   #10
troek
troek's Avatar
Drives: 2012 Toyota 86
http://www.ft86club.com/forums/showthread.php?t=79504
Old 12-21-2014, 03:03 AM   #11
edeekeos
edeekeos's Avatar
Really excellent deal^ someone buy that!!
The Following User Says Thank You to edeekeos For This Useful Post:
troek (12-21-2014)
most comfortable shock with Eibach Pro Kit Crashhollywood12 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 01-15-2016 12:01 PM
Which is the most comfortable coilover on brz/frs?? HowL Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 04-27-2015 08:02 AM
Comfortable street-only winter-only dampers dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 11-22-2014 11:13 AM
For those who ride, there's a group ride happening tomorrow if you're interested. Yamaha_R6 Northwest 3 03-07-2014 09:32 PM
Lowering gear, AND keeping comfortable MarkMash Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 07-17-2012 02:12 PM
