Old 01-04-2017, 07:42 PM   #1
Uriahlizama
Drives: 2014 Scion FRS
OFH tune with Tomei Headers
Hi I was wondering if it was safe to use the OFH stage 2 tune with the Tomei UEL header. I am going to try tuning it and run some pulls and post the data logs here but I need help finding out if the logs look ok.
Uriahlizama is offline   Reply With Quote
Old 01-04-2017, 08:32 PM   #2
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
I've got this set up. No problems.
TruRace is offline   Reply With Quote
Old 01-04-2017, 08:38 PM   #3
steve99
if you have good quality 93 usa fuel you should be fine, but best to log and check fueling and knock parameters.
Old 01-04-2017, 09:07 PM   #4
Uriahlizama
We only have 91 octane here in Utah. The real time diag. showed no knock correction but im not sure about the fuel ratios. I am going to post the data logs here. Let me know if im missing anything.
Old 01-05-2017, 11:06 PM   #5
tCsonfrs
Drives: 10 Series FR-S #207
I've been running that header and tune since it came out, no issues at all. Just make sure you're running high quality 93oct and you're good
tCsonfrs is offline   Reply With Quote
Old 01-06-2017, 08:45 AM   #6
KDad2
KDad2's Avatar
Drives: 2013 Raven
I just got the Tomei EL header and overpipe, and Invidia catless front pipe and I have OFT. I can't wait to have them installed! I'm glad that nobody has had issues with this setup and a tune.
KDad2 is offline   Reply With Quote
Old 01-10-2017, 10:13 PM   #7
tCsonfrs
We're talking about UnEqual length headers in here, do NOT use that tune with your Equal Length header
Old 01-12-2017, 12:59 PM   #8
Italocardoso83
Drives: Scion Frs 2.0
quick question guys, you said dont run 91 oct on tomei uel headers with the flash?
Italocardoso83 is offline   Reply With Quote
Old 01-12-2017, 01:43 PM   #9
Icecreamtruk
Drives: Track preped NA FRS
You run the gas you have a tune for. If you flashed a 91oct tune for UEL headers then you use 91 gas, if you flashed a 93oct tune you use 93 gas. You can go up but not down. Meaning you can use 93 gas on a 91 tune but you shouldnt use 91 gas on a 93 tune.
Tomei UEL vs HKS/Tomei EL headers for gains max20s14 Engine, Exhaust, Transmission 37 05-28-2020 09:11 PM
OpenFlash Headers in 2017 &a Tune -- success & no tune yet gskv Software Tuning 151 03-29-2018 08:10 PM
I bought Tomei Headers and have OFT. Do I just flash the Stage 2 Tune? GT86 Guy Software Tuning 3 08-06-2016 06:44 PM
WTB Tomei Type 80, Tomei UEL headers Justin91M Want-To-Buy Requests 1 12-19-2014 11:42 AM
TOMEI UEL vs. EL headers (w/stage 2 OTS tune) UrmyboyBLUE Engine, Exhaust, Transmission 42 10-25-2014 02:16 AM
