Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
Safely raising rev limit?
What, realistically, would it cost to purchase valve springs and have them installed to safely raise the rev limit? What else (reasonable) can be done to raise the rev limit and what safe rev limits are realistically possible?
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
*Some really cool title*
What exactly would you be trying to accomplish by raising the rev limit? Max power is around 7000 rpm so all you'd be getting is some more noise.
With a lot of cars you can raise the limit with a tune but idk if it works for these. |
| The Following 2 Users Say Thank You to Silver Cervy For This Useful Post: | FRS Justin (01-07-2017), humfrz (01-04-2017) |
Dismember
Drives: 2013 Red Scion FR-S
The rev limit can be safely raised some. OFT makes it easy. They also put a soft rev limit, so it's not like hitting a wall with the stock one. Makes mistakes less punishing. Realistically, going over 7000rpm is either because of poor technique or wanting to stay in gear at a track. If you add a turbo, the game changes because then you may be able to make more power up high.
#4 | |
If you could do it without blowing the engine, I'd not be surprised to find sufficient power 300-500rpm higher than current limit.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#5 | |
Drives: 2014 GT86
1) due gearing ratio there is still more torque going to wheels then at "more optimal" rpms/power curve peak but in higher gear 2) wider usable rpm range/ability to go longer at certain gear without upshifting or downshifting at many tracks may give extra advantage of loosing less time on gear shifts But at the end it's all upto reliability of very high-reving engine. And for that .. imho just valve springs might be insufficient. Fully built engine might be outside of budget of most though. |
A.K.A. Starlord
Drives: 2015 Series.Blue
FYI, autocross is an example of a situation where a slightly increased rev limit would be useful.
| The Following 5 Users Say Thank You to Stang70Fastback For This Useful Post: | CTB727 (01-07-2017), Hades (12-16-2017), Keenercarguy (01-07-2017), tCsonfrs (01-10-2017), wparsons (01-04-2017) |
...Just add nauseum
Drives: 2003 (AP1) S2000
Ok, bickering aside, the upper limit of this engine is around 8200. It varies a little, but that's slightly below the point where the oil pump quits moving oil.
Some have done 7600-7800 on stock valve springs, after that you are on borrowed time until you upgrade them. Plan on paying $1200 to a good shop for parts and labor to swap the springs. Some have "solved" the oil pressure issue by fitting a massive Accusump accumulator to move oil after the pump quits doing it. They go to 9000 RPM... In short bursts. Their motors don't last. The oil pressure limit is a wall. You can't get past it with a "built" engine, don't waste your money. All proper high-revving engines use an underdriven oil pump that sits in the sump. This one settles with a direct-drive pump that sits on the crankshaft. Limitations are limitations. Cams will absolutely help. Stock advertised duration of 252/252 is not conducive to high RPM operation, regardless of what you do with VVT. Duration at .050 is even less. That's why the VVT angles are so wide... Not like the valves are gonna collide or anything. Higher redline is beneficial until the flywheel torque drops by the percentage gear ratio drop from one gear to the next. In short, it is beneficial on the FA20 to keep revving it. Get an equal length header with the shortest available runners, like the ACE / 150, if you want to actually make power up to redline. There is an intake manifold with shortened runners available, which has been tested, but it is very expensive. E85 will also help. UEL headers will choke the engine up high.
There are many ways to displace.
-Spartarus Last edited by Spartarus; 01-04-2017 at 09:59 AM. |
| The Following 18 Users Say Thank You to Spartarus For This Useful Post: | Cesium Rainbow (01-18-2019), churchx (01-04-2017), CxG (01-12-2017), FeRS (03-08-2022), gtengr (12-16-2017), Hades (12-16-2017), humfrz (01-04-2017), JoeC (01-04-2017), Keenercarguy (01-07-2017), kiichiro (01-07-2017), Nah (01-04-2017), RJasonKlein (01-07-2017), Stang70Fastback (01-04-2017), Teseo (01-07-2017), TofuJoe (12-13-2017), Turdinator (01-04-2017), Ultramaroon (01-04-2017), wparsons (01-04-2017) |
Mountain Runner
Right, A) I'd be moving to an Ace Clubsport (EL) if I decided to raise the rev limit, B) I'd be doing so for autocross because staying in a gear longer is quite valuable. I'm really curious to hear from people that *have* swapped the valve springs and are running a redline north of 7850.
#10 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
I havent been on the forumz in a while...
has anyone figured out how to put a FA20DIT and WRX ecu into a 86 yet? I'd come back to the platform for that.
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
#11 |
Drives: Late 2014 Subaru BRZ
At that point people are jumping over to Motec
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#12 |
Mountain Runner
Honestly at that point there are numerous forced induction options that are cheaper, plus FA20DIT's have had compression problems even on the stock tune/boost in WRX's… So I wouldn't even want to go that route at this point, personally.
| The Following User Says Thank You to Keenercarguy For This Useful Post: | why? (01-07-2017) |
#13 | |
Sarcastic SOB
And, a twin scroll with low end torque that tapers off up high goes against maintaining traction on a light rwd drive. Trust me on this, look at both my vehicles. The FA20DITdoes not have the ideal power curve for the twins. Oh, and the location of the turbo makes it not fit the engine bay.
| The Following User Says Thank You to wbradley For This Useful Post: | Keenercarguy (01-07-2017) |
| Safely Jacking and Supporting Your BRZ/FR-S | GrimmSpeed | DIY (Do-It-Yourself) Guides | 152 | 06-11-2021 07:44 AM |
| How many accessories can you safely connect? | FutureFT86 | Electronics | Audio | NAV | Infotainment | 6 | 01-31-2017 06:17 AM |
| Transporting e85 safely | Sonolin | Tracking / Autocross / HPDE / Drifting | 5 | 05-21-2013 03:33 PM |
| Adhesive Removal on Paint Safely? | Mac1235 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 9 | 01-10-2013 03:39 PM |
| How to Safely Wash Your Car in the Winter | Veloist | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 12-05-2012 12:31 PM |
