Old 01-03-2017, 10:48 PM   #1
JF86Red
Drives: GT86 C7P
DIAM FRONT BRAKE DISK
Hi All,
I don't find the diameter of front brake disk but I think it's 293mm for 86/BRZ.
For replacement we can find 277mm or 293mm, someone knows why these 2 sizes ?
JF86Red is offline   Reply With Quote
Old 01-03-2017, 11:15 PM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
In Australia there are 2 models of 86: GT and GTS. GT has 277mm diameter front discs. GTS has 294mm diameter front discs.
Having a quick look at the Toyota Europe website I'm guessing the corresponding models would be Standard and High.
JF86Red (01-04-2017)
Old 01-04-2017, 01:26 AM   #3
JF86Red
Drives: GT86 C7P
That's what I though but I never saw 2 models in Europe, at least in France only one that's why I was surprised to see 2 diam for the same level car on french's website for spare parts.
I will check on car the next time I can
Old 01-04-2017, 08:22 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
There were also 16" wheels on AUDM GT vs GTS trim that had 17", but all BRZs/GT86s in EUDM IIRC had 17". So i'd double-check which size ir right for EU twin. It's also possible for all of them @EU to have same brakes. BTW, why not ask at some local Toyota dealership in France, which part number brake disks are right for you according their part inventory system?
Old 01-04-2017, 01:17 PM   #5
jamal
jamal's Avatar
Drives: Legacy GT
You can tell from looking at it. There will be a pretty small gap between the caliper bracket and rotor hat for the 276mm brakes, like 5mm. The 294mm brakes will have more space, like 10-15mm.
Are the rear discs vented or not? solid rears would indicate the smaller fronts.
jamal is offline   Reply With Quote
Old 01-04-2017, 04:20 PM   #6
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
You could take your wheel off, grab some measuring tape and measure the diameter and then buy the appropriate one. Even if your measurement isn't exact, ~15mm difference will be obvious enough to tell which one you need.
Lynxis is offline   Reply With Quote
DIY: Front Brake Pad and Brake Rotor Replacement F1point4 DIY (Do-It-Yourself) Guides 28 03-21-2021 09:22 PM
BRZ OEM Brake Disk (Rusting?) Border7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-15-2014 02:49 PM
FS FX350 Disk Sportsguy83 Transmission and Driveline 14 02-04-2014 11:15 AM
SSR disk sizes fiveoneone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-18-2012 05:17 AM
