Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Members Classifieds > Transmission and Driveline
Old 01-18-2014, 11:33 PM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
FS FX350 Disk
FS is a slightly used FX300 disc. MSRP is $300, I'll sell it for $210 shipped CONUS.
Full Face in the pic below.
This is a GREAT upgrade for whomever bought an FX400 but is hating the drivability of it. (Both kits use the same FW, TO Bearing and Pressure Plate, the disk is the only difference.)
Old 01-18-2014, 11:40 PM   #2
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
is this the fx350 or fx300? I'm a little confused because the post title says FX350 but in the post you state fx300.
toekneehair is offline   Reply With Quote
Old 01-20-2014, 11:07 PM   #3
Sportsguy83
Drives: Limited BRZ
Well, it LOOKS like an FX350 disk, but CM has labeled the boxes of FX300/350 kits for the twins as FX300.
The Price list for 2013 shows it as being FX350.
In conclusion, there is no FX300 AND FX350 kit for our cars, so the disk I have is the only 300 series available for our cars.
Old 01-24-2014, 10:02 AM   #4
hunter3232792
hunter3232792's Avatar
Drives: FRS
great clutch great person glws!
hunter3232792 is offline   Reply With Quote
Old 01-24-2014, 10:17 AM   #5
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
That's a pretty good deal and it's one of the kits I've been looking at. I'd be interested but I would need to find the rest of the parts to complete a kit. Does CM allow you to use the original FW from our old clutch? Then I just need to order a TO bearing and Pressure Plate
shiro is offline   Reply With Quote
Old 01-24-2014, 12:12 PM   #6
Sportsguy83
Drives: Limited BRZ
Unfortunately no, they require the custom FW.
Old 01-27-2014, 07:59 PM   #7
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
what are you running now? I need to swap out my clutch, that exedy just ant gonna do. I really am lost for what to put in. Need something that can handle at least 320-350tq
gdrider77 is offline   Reply With Quote
Old 01-28-2014, 08:14 AM   #8
Sportsguy83
Drives: Limited BRZ
FX400. Six puck clutch is the way to go for that level of WTQ.
Old 01-28-2014, 06:12 PM   #9
gdrider77
gdrider77's Avatar
You are running the fx400? how driveable is that? Not that i drive all that much, but would still like to be able to putter around town....
I was looking at the 350 for mine, as that seems like it would work, is that what you have? What else would i need to purchase from clutchmasters to make this work?
Old 01-28-2014, 07:25 PM   #10
Sportsguy83
Drives: Limited BRZ
With the AVO Turbo you won't get higher than say 280 WTQ. The 350 will be more than enough. Unfortunately you will need pressure plate, Flywheel and throw out bearing from Clutchmasters.
Get in contact with FT86speed factory to see how much it is for all in if you save any money versus the regular kit that goes for about 1K.
I can lower it a bit for you if it is close to making sense pricewise.
Old 01-28-2014, 07:36 PM   #11
gdrider77
gdrider77's Avatar
making around 320 wtq right now, thats the problem. The exedy i have wont hold up. didnt expect to be making that much honestly, so thought the exedy would hold.
Old 01-29-2014, 02:59 PM   #12
shiro
shiro's Avatar
To my understanding the FX350 should be able to hold what your gains are. I was able to get a full kit for in the 800's (not to steal your thunder David). I'm hoping to see if I can push 400whp and 400tq on her. If it doesn't hold I'll just buy the FX400 disc (not the whole kit again).
But honestly, you should by the FX400 kit and this disc (FX350 from David) since you can interchange the clutch disc with the Flywheel and Pressure Plate from the kit. Bonus! lol
I can't believe I didn't think of that until now... -_-'
Old 01-30-2014, 12:41 PM   #13
gdrider77
gdrider77's Avatar
Kind of confused on this statement, why would i buy both? Couldnt i just buy the fx350 and be done? Seems that both are about the same price.
Old 01-30-2014, 01:31 PM   #14
shiro
shiro's Avatar
I referred to buying both of them since they use the same flywheel, pressure plate, etc. and if you didn't like the driveability OR you are feeling the clutch slipping you can just swap the discs. This way you don't need to buy a whole kit.
But this was just an option if you aren't sure what you like. Everyone has their own preference...
Work Wheels.. Disk sizing ? Juvenile Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 05-11-2016 04:40 PM
Problems with FX400 full-disk clutch after shady install... ***Help?*** Argento_FR-S Engine, Exhaust, Transmission 4 05-29-2013 02:29 AM
Why did my disk rotors turn white? Hags86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-11-2013 03:53 PM
SSR disk sizes fiveoneone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-18-2012 05:17 AM
convert drum to disk brakes DIG1992 Other Vehicles & General Automotive Discussions 2 11-09-2011 05:04 PM
