Old 01-01-2017, 06:28 PM   #1
zman
zman's Avatar
Drives: scion frs
Tire questions
I recently purchased winter tires after learning my lesson from last winter. I went with the champiro ice pro 235/45/17 mounted on the OEM wheels.
What psi should I inflate them? I currently have them at 33psi but it seems kinda low.
Also, do all FRS have the same TPMS codes? I bought some aftermarket wheels from a member and it came with the TPMS.
zman is offline   Reply With Quote
Old 01-01-2017, 07:05 PM   #2
humfrz
I would think that 33 psi would be OK for those tires. However, if they feel squeeeeshy, you may want to kick them up a few psi.
This thread may shed some light on your TPMS question:
http://www.ft86club.com/forums/showthread.php?t=82211
humfrz
Teseo (01-01-2017), zman (01-01-2017)
Old 01-01-2017, 08:24 PM   #3
zman
zman's Avatar
Drives: scion frs
humfrz
I'm still confused about the tpms. The person who sold them to me, said that he copied the oem codes to the aftermarket wheels. Now do all wheels have different codes compared to other FRS cars?
Old 01-01-2017, 09:03 PM   #4
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
every tpms has a different signal so cars that are near each other do not get confused. A dealer or good aftermarket wheel and tire person can get them to work for you.
As for pressure, definitely go higher. I pumped mine up to 40 because it made them feel better on dry pavement. But it depends on how you want them to feel and what the max pressure for your tires are.
The Following User Says Thank You to why? For This Useful Post:
zman (01-01-2017)
Old 01-01-2017, 10:26 PM   #5
zman
zman's Avatar
Drives: scion frs
What size tires do you have
Old 01-01-2017, 10:31 PM   #6
why?
why?'s Avatar
Drives: series.blue
I have general altimax artics 205/55/16.
zman (01-01-2017)
Old 01-01-2017, 10:53 PM   #7
cjd
cjd's Avatar
Drives: 2017 BRZ
Lower pressures can be helpful if it is icy/snowy, but it can be OK to go up some for between crap. They'll always be squishier, and always be less performant in dry/wet. I run 36psi and drop it if needed.
The Following User Says Thank You to cjd For This Useful Post:
zman (01-01-2017)
Old 01-04-2017, 10:33 PM   #8
zman
zman's Avatar
Drives: scion frs
I drove it today and it definitely needs more air. The car wiggles a lot and the abs kicks in a lot while making turns . Not sure if it's the tire size or warm weather.
Old 01-06-2017, 07:35 PM   #9
why?
why?'s Avatar
Drives: series.blue
it is the lack of traction. Winter tires have less traction than stock. The only time I've ever had the traction control kick in is when I have winter tires mounted. I even managed to do a 4 wheel drift in the rain on an on ramp with the stock tires and traction control acted like it was normal and nothing to worry about.
Old 01-06-2017, 07:47 PM   #10
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Why do you want to use the TPMS from the other member, if you still have your OEM wheels, you should just use those.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 01-06-2017, 07:51 PM   #11
zman
zman's Avatar
Drives: scion frs
Im keeping the oem wheels for the winter tires.
Old 01-06-2017, 07:58 PM   #12
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Keep it in 33~36 psi is fine.
As for car wiggling is due to soft wall, it's something that need to get used to, but it's somewhat common in winter tires. As for ABS kicking it, it's your driving. Gotta learn summer driving and winter driving
zman (01-06-2017)
Old 01-06-2017, 08:12 PM   #13
This^
I am running the Champiros as well and they have a very aggressive tread that will walk through the worst ice and snow thrown at them but are not fond of warm, dry conditions. Don't go nuts with the pressure since they get even more squirrely if to high. I stick to 34PSI.You will get used to them. They are a surprisingly good tire for the price.
zman (01-06-2017)
Old 01-06-2017, 08:29 PM   #14
zman
zman's Avatar
Drives: scion frs
Yes I do drive a bit hard. Also, I noticed that it was very dangerous going over 70 as the car was very unstable.
Tire Rotation Interval Questions HunterGreene Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-03-2016 09:40 PM
Wheel/Tire Questions Regarding Width Strife26 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 04-04-2016 01:09 PM
Winter Tire questions 2015 FR-S Sapper211 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-03-2016 03:14 AM
Tire questions Thataznguy001 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 01-03-2015 06:55 PM
Couple tire/wheel questions Jayde Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-19-2012 02:18 PM
