Old 12-28-2016, 08:11 PM   #1
whjdm069
Drives: 2015 scion frs
Help looking for concave wheels
Looking to run 18x8.5 all 4 corners. Tire size 225/40 /18. Lowered on eibach sportline springs. Not sure what wheels are out their that have a deep concave or something with a good size lip. I have been searching for weeks but pics don't always show how concave or the amount of lip a rim has. I have bought rims in the past that did not look like the pics once I got them. I'm also not sure on what offset I should run. I should mention I am looking for something in silver, gold, bronze or off greys. I am also looking to spend no more than 250 a rim. Thanks for any and all comments.
whjdm069 is offline   Reply With Quote
Old 12-28-2016, 08:19 PM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
So many questions but at least you are sure that you will be running a stretched tire. Good to see you have your priorities in check.
Originally Posted by humfrz
I'm old and lazy
Old 12-28-2016, 08:19 PM   #3
gramicci101
Off Topic
You're not going to get very concave wheels or wheels with a huge lip unless you go with a widebody kit. Especially not with an 8.5" wide wheel. Some of the 18x9.5s are somewhat concave, but not all that much. Your proposed price tag also seriously limits your choices.
This thread will probably be able to help you with your search the most.
http://www.ft86club.com/forums/showthread.php?t=25171
Old 12-28-2016, 08:29 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
My Konig Oversteer wheels are concave. Not deep concave, but that's not possible with the positive offset range the car has with a 8" to 9" wide wheel.
+30 to +45 is your offset range for 18x8 to 18x9 wheels.
I LIKE TIRES!
Teseo (12-29-2016)
Old 12-28-2016, 08:30 PM   #5
whjdm069
Thanks for the replies. I was afraid my budget was a little low. Maybe I will look into a wheel with a lip or not worry about the wheel being concave. Thanks
Old 12-28-2016, 08:32 PM   #6
whjdm069
I actually have these wheels in 17's. I like them but they have my winter tires mounted on them and I want to move to an 18.
Old 12-28-2016, 08:34 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
My wheels were 800 for 4. Not including tires. 1000 will buy a decent set of just wheels, though on the lower end.
Read through the wheel gallery...
I LIKE TIRES!
Old 12-28-2016, 08:35 PM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The 18x9 is fairly concave.
I LIKE TIRES!
Old 12-28-2016, 10:26 PM   #9
RJasonKlein
RJasonKlein's Avatar
Check out this thread I created asking for tire size suggestions for my 18"x8.5" +42 RAYS 57Xtreme wheels - they're probably going to meet all of your requirements, aside from price:
http://www.ft86club.com/forums/showthread.php?t=113279
RJasonKlein is offline   Reply With Quote
Old 12-28-2016, 10:47 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
$250 a wheel for 18s and sportlines tells us that. But a 225 on 8.5" isnt that bad honestly. 225 is an OEM size for an 8" (at least on GD STIs) so .5 more isnt that much
Teseo (12-29-2016)
Old 12-28-2016, 11:14 PM   #11
Legionsk88
Legionsk88's Avatar
Drives: 2015 WRB Limited BRZ
Ray Gram 57Xtreme Wheels with around +40 offset is the what i run and they have a pretty deep concave. i dont a pic up but i can post one if needed. they arent cheap and you can run 245 maaaaybe 225 but they will be stretched
Legionsk88 is offline   Reply With Quote
Old 12-29-2016, 03:23 AM   #12
whjdm069
I looked up the 245/40r 18 and I like the side wall profile better than the 225. The 225 in 8.5 looks stretched. If I go 8 wide then 225 is probably a good choice. Thanks for the replies and links.
Old 12-29-2016, 12:01 PM   #13
gramicci101
Off Topic
Don't get a 245/40-18; it's an inch taller than the OEM tire diameter. Get a 245/35-18. It's almost exactly the same diameter as OEM.
Old 12-29-2016, 12:15 PM   #14
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I'm on Enkei T6S 18x8 and 18x9.5, they have a nice concave look.
Current DD: M235i
8RZ is offline   Reply With Quote
Lightweight concave wheels for wide body WallsAndFoundations Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-18-2015 07:51 PM
TiS Concave TiS536 18x8 Wheels FR-Shred Wheels and Tires 0 05-05-2015 01:26 AM
Favorite Non-Concave Wheels on the 86? bobsacamenoh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-09-2014 07:05 AM
concave wheels jdmblood Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 12-02-2013 03:15 PM
What wheels are these? SUPER DEEP CONCAVE ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 02-20-2013 08:05 PM
