Old 12-28-2016, 04:15 PM   #1
rubbercow
Drives: 2022 GR86 (formerly 2014 BRZ)
Alternate location for reverse camera (HowTo)
I mounted up a Rydeen Duo on my Subaru BRZ using this post:
BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures)
I found that I didn't like the OEM location much. When parking, the driver side parking lines, or curb, or other cars... strongly favored the passenger side visually. At times, it took a bit of mental arithmetic that I couldn't afford in my rush to avoid inconveniencing others. As a result, I removed it and installed it differently: in the center.
Comparison of OEM (top) and centered (bottom):
OEM location:
Alternate centered location:
What it looks like mounted (
the back hangs on the ridge):
Also, I no longer have a stock headunit. As such, these are the wires to tap in the rear trunk, along the back trunk wall:
rubbercow is offline   Reply With Quote
Old 12-28-2016, 04:25 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Great write-up, I'm really interested in adding a backup cam as well.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 12-28-2016, 05:20 PM   #3
FX86
i bought this shit...doesn't fit because the camera won't go through the trunk garnish so i mounted it with 3M tape to the trunk...at least the video quality is good
Old 12-28-2016, 08:51 PM   #4
8RZ
The Gunshine State
8RZ's Avatar
3M tape is enough to keep it mounted even with the Florida heat? Which model is that?
Current DD: M235i
Reverse Camera Suggestions?? 5irestormer Electronics | Audio | NAV | Infotainment 6 11-07-2016 03:33 PM
FYI - it's possible to add a reverse camera for $20. SloS13 Electronics | Audio | NAV | Infotainment 25 09-09-2013 10:03 PM
Reverse light wire location? derka-derka AUSTRALIA 1 05-29-2013 09:19 AM
Reverse Camera FT86_Zero Scion FR-S / Toyota 86 GT86 General Forum 26 08-05-2012 08:05 PM
Reverse camera? dorkymork BRZ First-Gen (2012+) — General Topics 28 05-21-2012 10:21 AM
