Old 11-06-2016, 04:03 PM   #1
5irestormer
5irestormer's Avatar
Drives: Fr-s 2015 Halo Color
Reverse Camera Suggestions??
Im looking into install a Reverse camera on my 2015 Fr-s. anyone with suggestions on which one to buy? I prefered one that doesnt require drilling.
5irestormer is offline   Reply With Quote
Old 11-07-2016, 06:54 AM   #2
Chimera
Drives: FRS
Required drilling, but I am running a Rydeen ZH07-150B Mobile Duo. I couldn't be happier.
Old 11-07-2016, 06:59 AM   #3
mende21
I just installed the same one. Feels solid, not cheap. The only drilling is through the plastic piece above the license plate.
mende21 is offline   Reply With Quote
Old 11-07-2016, 08:05 AM   #4
jasonojordan
Drives: 2013 satin white brz limited
I have the same one as the above two. Works great never had any issues with fogging over after car washes or not being able to see in the rain. Have had it for 2 years.
jasonojordan is offline   Reply With Quote
Old 11-07-2016, 02:04 PM   #5
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
I put one of these in a few weeks ago...no drilling, or even screws or tape needed:
https://www.amazon.com/Navinio-Impre...+backup+camera
While it is an exact fit for the OEM light (size/clips), it won't install as intended on these due to the angle of the camera mount vs. the trunk handle. However, if you remove the camera from the light housing it is exactly the right size to firmly tuck in between the handle/body and the wire can be run through the light housing...painless.
BRZyJ is offline   Reply With Quote
Old 11-07-2016, 02:48 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Beatsonic makes one that screws into the license plate bolt, kinda neat if you don't want to drill
Old 11-07-2016, 03:33 PM   #7
86Boyz
Drives: on the highway to hell
I installed one very similar to this. Acts as a license plate frame and works as a camera. Great quality and has backup lines. They can be found on Amazon for those that are looking.
86Boyz is offline   Reply With Quote
Help With Reverse Camera Install tiz22 Electronics | Audio | NAV | Infotainment 28 09-08-2019 12:06 AM
FS: Subaru BRZ OEM Reverse Camera Euro7R Canada Classifieds 1 05-06-2015 04:25 PM
FYI - it's possible to add a reverse camera for $20. SloS13 Electronics | Audio | NAV | Infotainment 25 09-09-2013 10:03 PM
Reverse Camera FT86_Zero Scion FR-S / Toyota 86 GT86 General Forum 26 08-05-2012 08:05 PM
Reverse camera? dorkymork BRZ First-Gen (2012+) — General Topics 28 05-21-2012 10:21 AM
