Old 12-26-2016, 08:30 PM   #1
Madara
Drives: 2014 Asphalt FRS
Decreased mpg due to mud guards?
Hey guys Ft86club community. I recently bought a 2014 Asphalt FRS about 2 weeks ago . Really excited about the car! I do have a question though(topic title). Is that possible? I haven't really noticed a difference yet since I haven't driven the car in the highway with them installed but just an idea... I just recently installed them as well.(OEM)
Madara is offline   Reply With Quote
Old 12-26-2016, 09:22 PM   #2
ryoma
ryoma's Avatar
doubt it. your driving habits will affect MPG the most
Old 12-26-2016, 09:56 PM   #3
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
The OEM ones are pretty skinny and work well with the stock wheels. The wide rally armor flaps are more likely to cause significant drag. But idk how much more likely.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Jajanken86 is offline   Reply With Quote
Old 12-27-2016, 12:19 PM   #4
FX86
what color are they?
Old 12-27-2016, 12:38 PM   #5
D_Thissen
D_Thissen's Avatar
You're joking.. Right?
Old 12-27-2016, 12:44 PM   #6
new2subaru
Weight Weenie
Drives: 15 FR-S
Just add some of these and you'll even out.
Old 12-27-2016, 12:48 PM   #7
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Drill some speed holes in the mudflaps for IMPROVED MPGs.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 12-27-2016, 01:43 PM   #8
JD001
JD001's Avatar
Drives: Subaru BRZ
Speed holes?? Is this like a vortex cyclone device that creates a vacuum on the attacking face thus sucking air through creating rush on back face that aids drag reduction and gives a positive airflow pattern that helps to self clean the car?
Old 12-27-2016, 02:05 PM   #9
8RZ
The Gunshine State
8RZ's Avatar
Precisely!
Current DD: M235i
Old 12-27-2016, 02:39 PM   #10
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
From the manual:
"After the installation of OEM mud flaps, three important steps must be taken:
1 - decrease the normally recommended tire pressure in each tire by 20 psi so that the reduced tire/wheel weight and (lowered vehicle) drag reduction will offset the mud flap drag effect on mpg numbers;
2 - increase the normally recommended tire pressure in each tire by 20 psi so that the reduced rolling resistance will offset the mud flap drag and tire pressure reduction instructions (in step 1 above) effect on mpg numbers;
3 - shine a flashlight into your left ear - a beam visible from your right ear means you're on empty - contact your dealer."
geezerbrzeezer is offline   Reply With Quote
Old 12-28-2016, 03:32 AM   #11
Madara
Thanks guys for some feedback. As for the the others commenters I've heard mud flaps decrease mpg due to having more drag. I was only curious and asking a legitimate question. Thanks though.
Old 12-28-2016, 04:23 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
They may decrease slightly at highway speeds. I don't think you should care though, after all, you install them to protect paint, so probably that is of more importance then slight MPG drop, right? Also IIRC USDM fr-s-es might lack plastic underside body panels. If you care about MPG that much, you may consider retrofitting those to reduce drag.
Old 12-28-2016, 08:06 AM   #13
8RZ
The Gunshine State
8RZ's Avatar
Hopefully my shark fin antenna drastically improves my MPGs.
Current DD: M235i
Old 12-28-2016, 08:26 AM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
All of those parts, antenna, sidemirrors, underpanels change drag by little. "Drastically"? If only by placebo feel. Though if they all are changed, cumulative difference probably will be noticeable enough (guesstimate combo of all those to be worth some .. 2-3mpg? And then again putting on stickier tires or big GT wing will make those efforts naught again ).
OEM mud guards fitcious Scion FR-S / Toyota 86 GT86 General Forum 37 08-04-2015 09:54 PM
OEM Mud Guards Annahra Exterior Parts (Aero, Lighting, Etc.) 2 03-04-2015 06:42 PM
WTB: OEM Mud Guards akiranakayama Exterior Parts (Aero, Lighting, Etc.) 0 03-25-2014 01:09 AM
FS: OEM Mud Guards White0utFrs Exterior Parts (Aero, Lighting, Etc.) 7 03-21-2014 01:21 AM
Anyone getting mud guards? zoomzoomers BRZ First-Gen (2012+) — General Topics 13 06-15-2012 08:40 AM
