Old 12-14-2016, 11:52 PM   #1
Itssrayyxd
Drives: Scion frs.
Help with tire size please! Too much rubbing
Hey guys,
So my current wheels are 18x8.75 +35 with 245/40/18 tires. I'm lowered on ST Coilovers. It rubs a lot especially when the is at full lock. Fortunately, they are starting to bald so I am in the market for new tires however I'm not too familiar with tires sizes. I was looking into Hankook V12s but im not sure what size tires would eliminate the rubbing. If you guys could help give me some advice that would be much appreciated.
Also, if you guys have any other tire recommendations thatd be great as well. Not looking for something too expensive as I am tight on money and still in college.
Itssrayyxd is offline   Reply With Quote
Old 12-15-2016, 09:32 AM   #2
Cole
Not a troll
Cole's Avatar
Where are you rubbing? Front? Back? Both? Inside the fender? On the frame? On the suspension?
Old 12-15-2016, 10:03 AM   #3
davmandave
Drives: 2016 Scion FRS, Pearl White, M/T
There is a tire sizing chart in the Tires Forum. Are you lowered more than 1"?
Keep in mind, this would only help for rubbing on the fender wells. Any other issues are probably going to be from having wheels that are too wide. However, since you are running 245s and I am on 265s (shout-out to the meaty tires thread), I'm guessing you are rubbing in the fenders from being lowered too far.
Just check out the sizing thread, or raise the car up a little more.
davmandave is offline   Reply With Quote
Old 12-15-2016, 10:10 AM   #4
Peaty
Scooby***s Guy
Peaty's Avatar
Drives: 2019 Impreza Sport - MT
http://www.wheel-size.com/calc/
https://www.rimsntires.com/specspro.jsp
good sites to check out
Peaty is offline   Reply With Quote
Old 12-15-2016, 10:57 AM   #5
gregman
gregman's Avatar
Drives: Boner Garage
here is another site.
http://www.willtheyfit.com/#isPage=1
gregman is offline   Reply With Quote
Old 12-15-2016, 06:07 PM   #6
Itssrayyxd
Drives: Scion frs.
I'm just rubbing inside where the plastic gender lining is. And all sides rub whenever there's a big enough bump or dip
Old 12-15-2016, 06:24 PM   #7
swarb
1. 245/40-18 tire is too tall. Full inch taller+ than stock. 245/35 is a better choice.
2. Not enough camber.
3. Too low.
4. Suspension too soft.
Most of the rubbing is caused by number 1 without knowing the rest of your setup.
The Following 2 Users Say Thank You to swarb For This Useful Post:
Brayden_23 (12-15-2016), Leonardo (12-15-2016)
NEED HELP with tire size TeamJacobs Northwest 3 08-11-2015 08:37 PM
Tire compound vs Tire size Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-22-2015 10:55 AM
What size tire should I run? HGaudio Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 06-18-2015 06:09 PM
Appropriate tire size for 250-350 whp Tiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-12-2013 02:40 PM
Tire rubbing sound, Please Help dco107 Scion FR-S / Toyota 86 GT86 General Forum 6 01-11-2013 10:05 AM
