Drives: 2015 WRB Limited BRZ
Bluetooth volume
Am I the only that seems to think the any music played via Bluetooth seems a notch or two lower in volume than the regular radio? I tend to use spotify and more times than not I find myself needing to go almost 3/4 of the max volume. Anyone else have issues with this? (ps. I found a previous post about this but no good solution)
Sent from my SAMSUNG-SM-G920A using Tapatalk |
Well, I'm no audio expert, but it wouldn't surprise me that a little energy is lost in the transfer ......
![]() Maybe the folks over in the audio section of the forum can shed some light on this question ..... ?? humfrz |
#3 | |
2. Adjust volume on head unit or use equalizer to adjust the signal. 3. SVC (sound volume control?) function on the head unit, it does not work for all the channels though. |
yeah bluetooth volume is lower..that's why i play all my music off of the usb now...higher fidelity too
Drives: Scion FR-S
Same reason most non-compressed CDs have much better volume and clarity then even a direct headphone jack.
This is because Bluetooth (in this instance) is being used as a wireless connectivity for sound, so the initial volume is controlled by the sending device. The receiving device (the headunit) can multiply that volume but only so much.
As @swarb said, start with your phone (or whatever the device is) first, then adjust the radio. My phone, for example, won't broadcast sound above what it believes is the max volume for a headset. To go beyond that you have to acknowledge that, "yes, I know if I listen at a higher volume I will most likely go deaf". When connecting over USB, the headunit is given more control. yes, this is an oversimplification and there are exceptions, but this is how it works most of the time.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
I never had an issue with Bluetooth volume on my iPhone, but I do have Sound Check and EQ set to None. Sometimes the phone volume buttons will affect volume.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
Drives: 2017 BRZ
Be wary boosting beyond the normal volume control max... It can clip the output signal, and that sounds horrid even to deaf people that can't hear the horrible contribution of mp3 compression.
I actually run ~80% volume on the phone and crank the head unit to 7 or 8, though it goes a little higher on the highway what with the exhaust noise. As long as there is enough power,nothing wrong with this at all. |
| FRS/BRZ Volume level | Scionguy28 | Electronics | Audio | NAV | Infotainment | 7 | 12-03-2014 07:31 AM |
| volume too low w\ audio from Bluetooth | JoeC | Electronics | Audio | NAV | Infotainment | 16 | 10-30-2014 01:27 PM |
| Bluetooth Volume not Being Saved | AmonReviled | Electronics | Audio | NAV | Infotainment | 0 | 07-17-2014 03:29 PM |
| Volume control with Bluetooth audio | finch1750 | Electronics | Audio | NAV | Infotainment | 5 | 02-17-2013 04:48 AM |
| Fluctuating volume | so26 | Issues | Warranty | Recalls / TSB | 9 | 08-16-2012 12:26 AM |
