Old 02-15-2013, 11:13 AM   #1
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Volume control with Bluetooth audio
So I just got a new phone (Xperia TL) and am having volume issues. Whenever it is connected via Bluetooth, the HU does not allow me to control the volume. I don't remember this being an issue on my old phone or my GFs. Anyone else have a similar issue?
Old 02-15-2013, 01:33 PM   #2
steve87j
steve87j's Avatar
Drives: Scion FR-S RAVEN
its the app that controls it. some work and some dont
steve87j is offline   Reply With Quote
The Following User Says Thank You to steve87j For This Useful Post:
finch1750 (02-15-2013)
Old 02-15-2013, 02:57 PM   #3
I have the same problem with my Droid X.
Not sure it works with all phones but I can adjust it if I'm really quick about it right after first switching to BT on the radio. Then the phone takes over control, which provides limited up/down movement. Others have reported here that that works as well.
Old 02-15-2013, 04:07 PM   #4
finch1750
finch1750's Avatar
Thanks Dadhawk. I'll give it a shot. Better to crank it too loud and turn it down on the phone then struggle to hear.
Old 02-17-2013, 04:18 AM   #5
finch1750
finch1750's Avatar
Just an update for anyone with the issue. I was able to adjust the volume when on the BT option on the HU as long as my phone was not connected. Didn't matter if it was right before or I was just sitting there messing with it.
Dadhawk (02-18-2013)
Old 02-17-2013, 04:48 AM   #6
leon78
leon78's Avatar
Drives: 13 Whiteout
I found this same issue....The volume adj work for the first few sec's you connect device..then its set to that level untill you turn off/on....and quickly adjust as needed.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Bluetooth Audio... Loathe it. seannyice81 Electronics | Audio | NAV | Infotainment 35 10-26-2013 02:10 PM
Bluetooth audio from android phone cgrey Electronics | Audio | NAV | Infotainment 10 07-11-2013 07:56 AM
bluetooth info, no audio? lbroskee Electronics | Audio | NAV | Infotainment 4 07-24-2012 09:22 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
