Old 11-20-2016, 09:45 PM   #1
javascripet
Drives: brz 2017
Wink where's the acc cable in the trunk?
i'v installed a wireless reverse camera and want to get power in the trunk instead of go through the car body
now i get energy on the licence plate light(in red circle), all the module and cable won't go out of the trunk cover, but the camera will only work when the light is on, it's inconvenience that i need to turn on the light on daytime when i need to use the camera
i've tried in other cable(green circle), they were not acc and always on, i think that's not safe
javascripet is offline   Reply With Quote
Old 11-21-2016, 12:08 AM   #2
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
closest wire would be on the amp by ur spare tire honestly
lbroskee is offline   Reply With Quote
The Following User Says Thank You to lbroskee For This Useful Post:
kevaughan (04-11-2022)
Old 11-21-2016, 01:11 AM   #3
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
+1
I cant think of anything else in the trunk that would be on at all times, only during ignition.
The stuff you circled in green: its for the key fob sensor so you can open the trunk with just the button, so yea that would always be on.
Not sure how the wireless camera works, but can you wire it to the reverse lights?
PandaSPUR is offline   Reply With Quote
Old 11-21-2016, 09:41 AM   #4
arrow34
Drives: Firestorm red FRS 2015
Well for the reverse camera, I used the reverse light, which is only powered when you shift into reverse. You only want to power the camera when backing up right? If so you have to run the power line down into the truck down by the spare as PandaSPUR said. Search for an exact location and if you cant find it, I can take a pic.
arrow34 is offline   Reply With Quote
Gauge install, dash cluster light cable, Tach RPM cable help... Sportsguy83 Electronics | Audio | NAV | Infotainment 99 08-07-2016 10:36 PM
Recommended OC/LA shop to paint trunk spoiler and fill in trunk holes? tracerit Southern California 13 04-20-2016 12:39 PM
Trading Carbon Fiber VIS Racing Trunk for Asphalt Grey Trunk + Cash asphaltkyle Exterior Parts (Aero, Lighting, Etc.) 19 10-13-2015 06:51 AM
WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk R0ME0 Exterior Parts (Aero, Lighting, Etc.) 3 01-07-2014 09:36 PM
Trade my Crystal Black Silica BRZ limited trunk (w/ wing) for wingless trunk (SF Bay) Iamthebatman Exterior Parts (Aero, Lighting, Etc.) 2 07-18-2013 02:12 PM
