Old 11-14-2016, 06:47 PM   #1
Mattstermh
Drives: '13 FR-S A/T - Stock
CEL + Slip Light, 1st gear jolting forward
Just started happening on the way home from work. I noticed the car jolted forward as I was coming to a stop, and this continued to happen every time afterwards. I then saw the check engine light and the traction slip light I think it' called (looks like the car skidding with the two zig zags in front). Not sure what's going on, if it's the tranny.
My car is AT. Turning the car off and on didn't help.
Not my car but this is what it looks like :
Last month I did the 60k maintenance, changed diff fluid, brake flush, AT fluid, spark plugs, oil change, etc.
Car is completely stock.
Mattstermh is offline   Reply With Quote
Old 11-14-2016, 07:09 PM   #2
steve99
Could be many things,
read the CEL code with an OBD scan tool, some auto shops will read it for you.
some possibilities
bad wheel speed sensor
or could even be cam actuator issue
but all speculation till you read the error codes.
Tcoat (11-14-2016)
Old 11-15-2016, 08:20 PM   #3
Mattstermh
Turned the car on today (didn't drive it) CEL was on but Slip light was gone. I used the diagnostic tool and got P0000 which means no fault. The blinking letters were C, O, E, EV, and OH. Not sure what those mean
Old 11-15-2016, 08:24 PM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
Do you have any devices plugged into the ODB port? A bad connection could trigger this.
Old 11-15-2016, 09:02 PM   #5
Mattstermh
Nah, nothing plugged in anywhere. I have a feeling the tool I used wasn't sufficient for my car.
edit: no problem, light went away.
traction light, engine light = cam sprocket , ecu nivek111070 Issues | Warranty | Recalls / TSB 27 03-13-2016 09:28 AM
No traction control/ABS light on Hollwood_lives CANADA 6 01-13-2016 09:11 PM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
First Check Engine Light and Traction control QFry Issues | Warranty | Recalls / TSB 26 10-04-2014 11:27 PM
