Old 11-15-2014, 07:29 AM   #1
acro
Drives: GT-86
Error code dealer or no dealer
Hi i got a check engine light. Used Ecutek to check the engine code and got
error code C1241 from the ABS ECU, what does that mean. I have seen that code listed as a low battery problem from some toyota forums but why did it come from the ABS Ecu. Brake pads where changed the same day BTW
Can the dealership read and Clear error codes with my ecutek tune on board or should i just flash back to the stock ROM. But if i do flash back to stock the error code will go right?
acro is offline   Reply With Quote
Old 11-15-2014, 09:38 AM   #2
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I'm no expert, but unless your ECUTek tune changed something in the ABS system, the code should still be there when you flash it back to stock.
Also, IIRC its very VERY risky to flash a new tune when your battery is low.
That said, a quick google search says that C1241 is a low battery code, like you said. Try a new battery before going to the dealer.
Bobblehead is offline   Reply With Quote
Old 11-15-2014, 10:03 AM   #3
Foobar
SLO NO MO
Foobar's Avatar
I would reset the code and drive around for a bit to make sure the battery is fully charged. If it comes back, flash back to stock and bring it to the dealer.
Old 11-15-2014, 10:36 AM   #4
acro
Drives: GT-86
Ok sounds like a plan. Ill let you know what happens
Old 11-19-2014, 05:29 PM   #5
acro
Drives: GT-86
well i went on a long trip hoping the battery would gain charge. Seems as if that worked the light is gone
Error code B14A1... wth is it? SirBrass Software Tuning 4 04-24-2014 05:37 PM
Dealer can't read CEL code Eddie Issues | Warranty | Recalls / TSB 24 11-15-2013 01:05 PM
Quick question about a dealer trading another dealer for the BRZ I want Prog BRZ First-Gen (2012+) — General Topics 17 09-15-2013 03:03 PM
Would you buy a car from a dealer that stuck a dealer (ad) plaque or sticker on cars? HitTheGas Off-Topic Lounge [WARNING: NO POLITICS] 49 04-29-2013 03:37 PM
Servicing my FR-S at Subaru dealer rather than Scion dealer dnL Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 08-28-2012 07:25 AM
