Old 01-11-2016, 08:22 PM   #1
Scuba86
Drives: 2014 FR-S Monogram Raven
2 degrees of camber up front?
Is it possible to get -2 degrees of camber up front with oem top hats and camber bolts?
Scuba86 is offline   Reply With Quote
Old 01-11-2016, 08:23 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
With two sets of bolts, yes.
With one set, no.
jawn is offline   Reply With Quote
Old 01-11-2016, 08:30 PM   #3
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
I was only able to get -1.6 degrees up front, all stock only camber bolts (1 set).
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 01-11-2016, 08:36 PM   #4
jawn
jawn's Avatar
OEM crash bolts? I was only able to get to -1.3 on SPC camber bolts in the lower hole. Lowered on RCE Yellows. Thinking about biting the bullet and getting camber bolts for the upper hole.
Old 01-11-2016, 08:43 PM   #5
chas3wba0
chas3wba0's Avatar
Drives: Yes
I installed front camber bolts on stock suspension upper slots and had the alignment shop max out the negative camber. They got it to -1.5 and -1.8, so you can get close, but not quite to -2.
However, that was enough to drastically improve cornering grip.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 01-11-2016, 08:53 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
take your OEM bottom bolts (which are the OEM crash bolts btw) and throw them in thebupper hole. I maxed at -2.4 on RCE yellows that way
Old 01-11-2016, 08:55 PM   #7
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
I have the SPC camber bolts installed on the upper hole. Is there a reason you installed them on the lower hole rather than the upper?
Old 01-11-2016, 08:56 PM   #8
jawn
jawn's Avatar
Yeah, I'm poooondering. I'll probably do it in the spring.
Old 01-11-2016, 09:00 PM   #9
jawn
jawn's Avatar
Poor life choices, I guess.
Old 01-11-2016, 09:05 PM   #10
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
No biggie. You can always make your changes in the Spring, like you said.
Old 01-11-2016, 09:54 PM   #11
wparsons
wparsons's Avatar
You can also get to -2* by slightly slotting the upper strut hole.
flickr
Old 01-11-2016, 10:26 PM   #12
finch1750
finch1750's Avatar
thats where they are meant to go, though in theory you could have a different size and they go in the upper hole. You could put a smaller eccentric bolt in the upper hole but you run a greater risk of it slipping.
But the SPC bolt sold for our cars is 14mm and goes in the bottom hole. A 16mm bolt is needed for the top
Old 01-13-2016, 09:30 AM   #13
wparsons
wparsons's Avatar
^^ The whiteline instructions definitely say to put the eccentric bolt in the upper hole, and they're the same bolts as SPC.
flickr
Old 01-13-2016, 10:46 AM   #14
jawn
jawn's Avatar
The SPC instructions that I have are for the lower hole. They do make them in different sizes, you know.
Rubbing noise at ~70 degrees steering both ways 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-30-2015 08:13 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
29 degrees F in Texas--near sea level elevation dave77 Scion FR-S / Toyota 86 GT86 General Forum 28 01-06-2014 12:57 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
