Old 10-28-2016, 11:30 AM   #1
Norinradd
Drives: 2013 frs
Most Close to stock fit tire on 17x8.25
Will they fit .com tells me 245/40 on 17x8.25 is almost identical to how a 215/45 fits on the stock 17x7
But im being told theyre too heavy. Will slow the car down. To grippy. Ect... Theyre like decimal point differences. How can it be so bad!?!?!?!? Wtf. Lol. The speedo error is only -.4. Ive beeb suggested 225 45. Speedo error is -1.25. And its a bigger tire. So how is THAT not bogging the car down more.
Can someone who knows what theyre talkjng about pls just tell me. Simply. In numbers. I dont need an explinstion.
What tire size should i buy??? :| :|
Rim is 17x8.25
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 10-28-2016, 11:36 AM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Definitely don't want a 225 on a 8.25 (IMO) because they will have a stretched appearance. 245/40 will be the most likely tire selection for proper fitment.
This person did 235/45.... so. Yeah.
http://www.ft86club.com/forums/showthread.php?t=82876
Old 10-28-2016, 11:42 AM   #3
Norinradd
Drives: 2013 frs
Hm so those people say 235 45 is the best? Lol
Old 10-28-2016, 11:46 AM   #4
Norinradd
Drives: 2013 frs
235 45 says its almost an inch taller than stock? That seems like alot of tire. How is 245 40 "meatier" but has less tire height
Old 10-28-2016, 11:46 AM   #5
Norinradd
Drives: 2013 frs
245 40 is as close as it gets to stock. Says will they fit com
Old 10-28-2016, 11:48 AM   #6
Summerwolf
Panda Trueno
Summerwolf's Avatar
Not saying that, just showing you a different option with pictures.
IMO, 245/40/17 would be your best bet. Wide range of available tires, that are reasonably priced as well. Would look the "best", obviously that is subjective.... and it keeps your speedo as close to stock as possible.
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
Norinradd (10-28-2016), Teseo (10-28-2016)
Old 10-28-2016, 11:50 AM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
-How is 245 40 "meatier" but has less tire height
If you don't know how to read aspect ratios and answer this question there is a whole section on this forum dedicated to this.... Also, here you go.
http://www.tirerack.com/tires/tirete....jsp?techid=46
Old 10-28-2016, 11:53 AM   #8
Norinradd
Drives: 2013 frs
I understand what the numbers mean. I just dont understand how a bigger tire isnt meatier
Old 10-28-2016, 11:55 AM   #9
Norinradd
Drives: 2013 frs
235 45 is stretched and has more side wall. 245 40 has less sidewall and is less stretch. I dunno man its heiroglyphics to me
Old 10-28-2016, 11:56 AM   #10
Summerwolf
Panda Trueno
Summerwolf's Avatar
Because they're wider..... A 225 looks puny in width compared to a 245. The lower aspect ratio sidewall is what helps it look "right" when it is on the rim, and ultimately on the car. Which of these two physically look more purposeful? (size wise not tread design) I know it is a 15" wheel size, but beggars can't be choosers when they grab internet photos quickly.
The Following User Says Thank You to Summerwolf For This Useful Post:
Teseo (10-28-2016)
Old 10-28-2016, 11:57 AM   #11
Norinradd
Drives: 2013 frs
Hmmm. I hate having to make uneducated or unobserved decisions
Old 10-28-2016, 12:00 PM   #12
Summerwolf
Panda Trueno
Summerwolf's Avatar
Well, you've made about 18 threads about tire size, tire type, wheel type, ride height etc with a massive outpouring of help. If you feel like you're making an uneducated decision do the footwork and research until you feel confident. A lot of people on this and other forums have years of experience to draw from.
Old 10-28-2016, 12:01 PM   #13
Norinradd
Drives: 2013 frs
Hm ya 245 definitley looks more suited
Old 10-28-2016, 12:02 PM   #14
Norinradd
Drives: 2013 frs
I also wouldnt mind filling some wheel gap though. I am dropping car an inch aswell
17x8.25 tire size 225/45, 235/45 or 245/40? tracerit Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-24-2022 01:03 PM
How close is too close?: Gap between tire & spring perch kodyo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 09-20-2015 01:32 PM
Tire pressure for 245/40/17 on 17x8.5 Sean BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-22-2015 08:01 PM
Tire size for 17x8.5 +32 +42 giraffee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-06-2013 08:17 PM
Which tire size for 17x8.5? giraffee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-11-2013 07:26 PM
