Old 10-25-2016, 04:23 PM   #1
Rsmith954
Drives: 2013 Subaru BRZ
Question Need help with tire/wheel fitment
(All around) Will 245/35r19 tires with 19x9.5 +35mm wheels fit on eibach sportline springs?
that is my only modification to the suspension. Thanks
Rsmith954 is offline   Reply With Quote
Old 10-25-2016, 04:30 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Old 10-25-2016, 04:38 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
http://www.ft86club.com/forums/showthread.php?t=41083
First page has tons of good info.
245/35/19 25.75" OD
245/30/18 24.79" OD
215/45/17 24.62" OD
I would go with the 245/30/19, as it is closer to stock and will not change you speedo as much as the 245/35. Not to mention the 245/35 is 1.13" taller and a pound heavier.
Get coilovers for 19x9.5 front wheels.
http://www.discounttire.com/dtcs/infoTireMath.do Tire calc. check it out. It helps.
Old 10-25-2016, 04:44 PM   #4
Rsmith954
Thanks
Old 10-25-2016, 05:52 PM   #5
SpeedStarOne
Will it fit? Yes. However, you may run into some rubbing with that tall of a tire.
Leonardo has it right, go down to the 30 series tire and coilovers to get the right fit.
SpeedStarOne is offline   Reply With Quote
18x9 +30 wheel tire fitment help! Tomec.lunasin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 04-18-2016 04:37 PM
Nubby wheel/tire/fitment guy in need of advice 17x9+35 KevinK121 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2015 07:34 AM
Enkei T6S wheel and tire fitment question chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-30-2014 09:25 PM
need help with wheel/tire fitment bjun Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 07-04-2013 10:34 PM
Tire/Wheel fitment tool bakilman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-02-2012 06:19 PM
