Old 10-23-2016, 08:18 PM   #1
nhuyvan1106
Java Programmer
Drives: 2016 FRS Red
First time lowering the suspension. Need advice
I just bought a set of coilovers from Yonaka. They all have camber plates on top which means I can adjust the camber when the car is lowered without having to purchase adjustable control arms correct? Please help out, I am very new to the car mod game
nhuyvan1106 is offline   Reply With Quote
Old 10-23-2016, 09:02 PM   #2
bfrank1972
Drives: 2013 FR-S Argento
Nope, won't fix the camber in the rear, you'll need rear LCA's if you want to adjust rear camber. That said you can be just fine depending on what alignment specs you want and how much you're dropping the car.
What alignment specs you say? How much can I drop the car? Search this forum and you'll find all that info.
bfrank1972 is offline   Reply With Quote
Old 10-23-2016, 09:05 PM   #3
Tor
Tor's Avatar
Drives: Toyota GT86
There are "camber plates" and there are "adjustable camber plates".
Those in the rear are never adjustable on the FT86, hence you need lower control arms for the rear or live with the camber resulting from lowering. If you don't lower it crazy much, you can probably do without. Even if the camber is slightly off left to right in the rear, you probably won't notice depending on what you plan to do with the car.
Tor is offline   Reply With Quote
Old 10-24-2016, 01:50 PM   #4
nhuyvan1106
Java Programmer
I plan on going 2 inches lower, and do you know how much negative camber it will produces?
Old 10-24-2016, 01:52 PM   #5
nhuyvan1106
Java Programmer
It is my daily driver, I plan on lowering by 2 inches. Also, when I change the camber angle, do I need new alignment?
Old 10-24-2016, 02:12 PM   #6
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
After lowering the car, you will need to have it aligned as your camber and toe settings will have changed
asdf is offline   Reply With Quote
Old 10-24-2016, 03:04 PM   #7
wparsons
wparsons's Avatar
A 1" drop puts you at roughly -2.5*, a 2" drop will definitely be over 3*, probably more like -4*.
flickr
Old 10-25-2016, 02:18 AM   #8
nhuyvan1106
Java Programmer
So I do have to get a new alignment every time I adjust the camber, don't I?
Old 10-25-2016, 02:20 AM   #9
nhuyvan1106
Java Programmer
Dang, that sounds so bad. Looks like I have to buy a new set of adjustable LCAs then
Old 10-25-2016, 07:31 AM   #10
bfrank1972
yup, so better to bite the bullet and get camber control for the rear. a good performance alignment will run you $150+
Sent from my SM-N920V using Tapatalk
Old 10-25-2016, 08:35 AM   #11
Songha
Songha's Avatar
Drives: 2013 Scion FRS
I lowered my car ignorantly low, over 2" with the wheels tucked in and the camber is ugly as hell to me in the rear. I'm going widebody as soon I get a new wheel setup so I don't really care right now, I'm tired of going into my shed to look my RB v1 flares. I would also advise, during installation to make sure the end links are aligned and installed correctly or you may get noise. Make sure everything is tightened the right way, you may need adjustable endlinks as well going 2" lower. My alignment is fine though, I haven't gotten an alignment and no issues with my tires or anything aside from minimal camber wear.
2013 Scion FR-S | 6-MT | Raven Black | Performance Mods: Invidia N1 Catback, Invidia Catless Frontpipe, BC Racing Extreme Lows Coilovers, 1320 Performance UEL Catless Headers, 1320 Performance Overpipe, OpenFlash Tablet (Stage 2 UEL, 93 Oct. tune), Whiteline Front Swaybar, Whitelight Adj. Front Endlinks | Asthetic Mods: DS Style Front Lip, Rocket Bunny style flares, F1R F21s | MY BUILD THREAD!
Songha is offline   Reply With Quote
Old 10-27-2016, 02:15 PM   #12
nhuyvan1106
Java Programmer
Is there anyway you could give me the torque spec on each bolt please?
Old 10-27-2016, 02:17 PM   #13
nhuyvan1106
Java Programmer
Yeah, I will have XXR wheels size 17 by 8.25 offset +35 installed at Discount Tires this Saturday and they will do the alignment as well. Are they good at aligning the suspension?
Old 10-27-2016, 04:25 PM   #14
wparsons
wparsons's Avatar
Unless you've bought parts (camber plates or bolts up front, and adjustable control arm rear) they can only adjust toe.
I would take it to a performance shop unless "close enough" or "within the spec range" is good enough for you. Personally I want my alignment to be a lot more accurate than that.
flickr
adjustable, camber, camber plate, coilovers, control arms
Tein Street Flex suspension issue (lowering itself over time) Sportsguy83 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 64 07-26-2015 05:00 PM
Long time Lurker seeking advice on a budget suspension setup sunset_blvd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 12-28-2014 05:48 PM
Need advice lowering my car just a bit... dejxx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-08-2014 10:58 AM
Need some Lowering Advice / Rims kbass808 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 04-18-2014 02:19 PM
advice on lowering car. juanam0909 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 04-30-2013 04:23 PM
