Old 10-21-2016, 12:09 PM   #1
customfab87
customfab87's Avatar
Drives: 2014 FR-S 6MT
Can't get rid of TPMS light after putting OEM wheels back on
After doing much research and trying everything being suggested, I still can't get rid of my TPMS light.
1. I took off my original OEM wheels to run an aftermarket set w/ R compounds for about a month. Got the usual lights on, lights off. No big deal. Figured things would go away after going back to OEM.
2. I put my OEM wheels back on with the original sensors, and light has been permanently on for the past year.
3. I tried clearing all DTC's. Light stays on.
4. I tried "Waking Up" the sensors by dropping them at least 6psi within 30 seconds. Afterwards I filled them up to 32psi. I cleared all DTC's using Techstream. Light is off, but comes back on after 30 miles.
5. Techstream shows all 4 sensor ID's properly, and even their tire pressures accurately.
6. Last DTC I was able to pull was C2176, which according to https://techinfo.toyota.com/t3Portal...=1477066027695 is a "Malfunction in the tire pressure warning ECU internal circuit."
I'm a bit puzzled about this DTC, since I have never touched the TPMS receiver or ECU. Maybe I'm not refilling the tires enough at 32psi? Any suggestions would help. Thanks.
customfab87 is offline   Reply With Quote
Old 10-21-2016, 12:16 PM   #2
May be stating the obvious and you have already done it but have you unhooked the battery for a couple of minutes?
The old IT "Turn it off and back on" seems to work on many such issues here.
Old 10-21-2016, 12:19 PM   #3
customfab87
Have done that several times in the past. I think clearing DTC's does more than unhooking the battery.
Old 10-21-2016, 12:56 PM   #4
Was worth a shot. Clearing wasn't working.
Old 10-21-2016, 03:49 PM   #5
customfab87
I guess I was just under what the system thinks is acceptable. Hmmm kinda annoying I can't run a tire pressure that I like without the light coming on.
Old 10-21-2016, 04:42 PM   #6
ryoma
ryoma's Avatar
are you checking the tire pressure when cold? try upping the cold tire pressure to 34 and see if it still comes on. if you're checking it when it's hot, then that might be why
Old 10-22-2016, 04:08 PM   #7
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
Maybe someone with more TPMS knowledge can answer this, but maybe the TPMS sensor IDs are specific to which corner you're putting them? Maybe you didn't put the wheels back in the same location before you took them off.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 10-22-2016, 04:15 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
I have no problem rotating my tires. I don't think it matters.
Old 10-22-2016, 04:22 PM   #9
Ultramaroon
not playing cards
Have you tried going back to 35 psi to see if the light stays out?
I vaguely remember seeing in techstream a field for the alarm threshold. Might be wishful thinking but I could swear I saw it.
Old 10-22-2016, 06:02 PM   #10
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
When learning new TPMS sensor IDs, they must be entered starting with the left front wheel and proceeding clockwise around the car... so there is some form of position dependency. I have no idea if the OP has done some action that cleared the old codes...
In any event, a good tire store will reprogram this for you for free, even if you have not purchased tires from them. Discount Tire did it for me - no affiliation other than being a satisfied customer in the past. The actually swapped my wheels I did not buy from them and reprogrammed the new TPMS sensors for free - though in appreciation I tipped the tech $20.
nextcar is offline   Reply With Quote
Old 10-22-2016, 06:57 PM   #11
Ultramaroon
not playing cards
See, I thought I had read something like that. I wonder if the receivers aren't just sensitive enough to pick up the response signal no matter where the wheel unit is mounted.
Old 10-22-2016, 07:43 PM   #12
tobin
tobin's Avatar
Drives: '13 BRZ
I don't think it matters where the wheels are mounted on the car. I have rotated the wheels numerous times without changing positions with my ATEQ. Even after mounting wheels without sensors, you can start the car 10 feet away from a set of unmounted sensor-equipped wheels and the TPMS light will go off.
Like Ultra recommended try going up to 35 and see what happens...
tobin is offline   Reply With Quote
Old 10-23-2016, 04:01 AM   #13
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
As a side question...
Do you know how long it lasts the battery in the TPMS sensors? My OEM rims have not been used for 2 years and after the winter I'll need to mount them back in the car for the 3 year inspection.
Old 10-23-2016, 06:39 AM   #14
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
On most cars those batteries are good for at least 6 years.
Thinking of putting back stock exhaust frsqc Engine, Exhaust, Transmission 31 07-31-2018 07:55 PM
TPMS light michael317 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 08-05-2014 04:12 PM
Ride not as smooth after putting on new wheels B-R-Z Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 85 05-19-2014 10:21 AM
NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-23-2013 08:11 AM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 08:25 AM
