Old 10-08-2016, 01:52 AM   #1
Norinradd
Drives: 2013 frs
Filling in fender body kit screw holes
So when i bought car had body kit. Im not
A fan of them so i removed it. Theres two nasty screw holes thatre already stArting to rust. On the inside rear fender lip, along with those are the two empty holes on the other side of fender lip that come stock. Is there anyway to fill these? To prevent rust and to look like less of a hack job. I was thinkin some sort of body worker filler and a little dab of colour match!?
Anyone ever done anything like that?
Thanks
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 10-08-2016, 03:48 AM   #2
humfrz
Thanks
If the holes are where I think they are, you might consider cleaning them up, painting the rusted spots and then put some rubber plugs in them.
A picture would help us "see" where they are.....
humfrz
Old 10-08-2016, 12:59 PM   #3
Norinradd
Drives: 2013 frs
humfrz
You know where the stock holes are in the rear fender lip? The ones toward the rear of the car. That many people have complained about. Theyre exactly the same but on the other side of fender lip. Same size hole.
Old 10-08-2016, 01:17 PM   #4
humfrz
Yep, that's where I thought.
I will still suggest you clean them up, plug them and then maybe paint the plugs.
OR ........ ........just quit worrying about the little things ......
humfrz
Old 10-11-2016, 12:13 PM   #5
sirsol66
Drives: 2013 FRS- Hot Lava
Clean up all of the rust, touch it up with paint, and then put in a plug. I like to coat the plugs with a combination of lithium grease+ lightweight oil (best IMO is fluidfilm as its for this kind of application)
sirsol66 is offline   Reply With Quote
Old 10-16-2016, 10:54 AM   #6
ayyyypex
Drives: 2016 FR-S
if you want to do it properly and not worry about it later, weld it, grind it, little bit of fine filler, paint.
ayyyypex is offline   Reply With Quote
Old 10-16-2016, 03:01 PM   #7
humfrz
Have you ever tried to weld tin foil ...... then grind on it .... ??
humfrz
Old 10-19-2016, 11:17 PM   #8
Norinradd
Drives: 2013 frs
Tin foil ha! Uhg i dont care to do sand grind weld and paint half of my fender because of two little holes. I may just use paint brush and brush the holes with anti rust silver paint and then use two plugs. I thought there would be an easier store bought method for such a common thing. Like an expandable anti rust hole filler up to 3cm or something
local body shops to fill spoiler holes damaster32 Mid-Atlantic 3 06-10-2014 11:15 AM
What the hell do car makers NOT put the bottom two screw holes for license plates? tzhu07 Scion FR-S / Toyota 86 GT86 General Forum 10 11-13-2013 01:43 AM
Rear Fender holes- are screws missing here? Coolhand BRZ First-Gen (2012+) — General Topics 11 10-30-2013 03:28 PM
Request: Filling in holes from dealer license plate bracket? t00n3wb DIY (Do-It-Yourself) Guides 12 08-14-2013 08:06 AM
Filling holes in front grill? Fast_Freddy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-20-2013 11:44 AM
