What the hell do car makers NOT put the bottom two screw holes for license plates?
WELL?????
I have a license plate that I attached with double-sided tape on the bottom because the FR-S, like many cars, does not come with the bottom two screw holes. |
Does it really need four to hold the thing on?
To simply hold it here? Of course not.
To make it look clean? Yes. A common problem with license plates is that they are warped (due to the thinness of the metal). So if you want a frameless look, you pretty much have to tape the bottom to your car. |
Ahh. Although if I was after "clean" I wouldn't use screws at all.
Well, tzhu07, may I suggest you use a strong two sided sticky tape underneith to help support the plate and then superglue two bolts into the bottom holes, to match the top two .... ??
humfrz |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Adds lightness.
You could sandblast the back of the plate to make that lighter too
"I gotta rock." -- Charley Brown |
First 8600
Drives: Gen2 GR86
The WeatheTech ClearFrame license plate frame is gasketed to seal the elements off of the face of the license plate. In order to affect a complete seal fasteners are required top and bottom.
http://www.weathertech.com/clearframe/ |
AutoX-10/10ths every run
Sound systems can make the plate rattle. I put some padded tape on the backside of the plate for this reason.
#9 | |
Drives: 2013 FR-S Series 10
I just used double-sided tape on the foam that (I guess?) the dealer installed ... works well... guess I'm lucky enough to have a straight plate.
#10 |
Drives: FR-S 10 Series
My moron of a salesman used a drill to screw in my rear license plate and the nylon bushings (?) are stripped. Are there part numbers and a way to pop them out for replacement?
#11 |
Drives: '13 FR-S Whiteout M/T
I found one of mine was stripped as well when I went to replace the temporary tag with my license plate. The dealer's parts department said it would cost about $7 and they would have to order it. I said why should I have to pay for it when their employee damaged it putting on the temporary tag. They ended up finding a spare one in the service department, popped it in and was good to go.
| Plugging up license plate bumper holes? | JohnAyySays | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 04-12-2015 03:06 PM |
| Trunk License Plate plastic holes cracked | Wes | Issues | Warranty | Recalls / TSB | 9 | 02-21-2013 11:36 PM |
| No Holes License Plate Review! | HATED1 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 09-10-2012 05:44 PM |
| Bumper Plugs for License Plate holes by dealer? | mikeg7827 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 08-13-2012 05:33 PM |
| License plate holes - Dealer installed for sure? | FastLap | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 08-05-2012 03:20 AM |
