Old 09-30-2016, 08:17 AM   #1
jefars
Drives: FRS RED
Best price for a "complete" kit of bushing urethane?
How to be sure you have a "complete" set of urethane bushing in a good price?
(suspension only, without transmission shifter diff.)
energy suspension =
http://www.energysuspensionparts.com...scion_frs_2013
HYPERFLEX MASTER KIT Price: $285.50
Includes:
Front Control Arm Bushings - 8.3131
Front Rack and Pinion Bushing Set - 8.10105
Front Sway Bar Bushings Set 21mm - 8.5138
Shifter Bushing Set - 8.1105
Rear Control Arm Bushings - 8.3130
Rear Sway Bar Bushing and Rear End Link Assembly 14mm - 8.5139
REAR VEHICLE ESSENTIALS KIT Price: $242.82
Includes:
Rear Upper Control Arm Bushings - Inner Position - W63225
Rear Subframe Mount Inserts - KDT922
Rear Differential Bushings - KDT925
Rear Trailing Arm Bushings - Lower Front Position - W63414
This is complete for 527$ ?
(No Rear Lower Control Arm Bushings & Camber Adjusting Bolt Kit)
double parts ? (Rear Control Arm Bushings ?)
Bonus: Rear Differential & Shifter Bushing
or
whiteline suspension =
http://www.whitelinesuspensionparts....scion_frs_2013
FRONT VEHICLE ESSENTIALS KIT Price: $224.82
Includes:
Front Lower Control Arm - Inner Front Bushings - KCA434
Anti Dive Caster Kit
Front Lower Control Arm - Inner Rear Bushings - W0509
Front Camber Adjusting Bolt Kit - 16mm - KCA416
Front Steering Rack Bushings - KSR210
Includes:
REAR CONTROL ARM - LOWER INNER BUSHING Price: $40.32
(Whi this parts is not Essentials ?)
This is complete for 524$ ?
(No Sway Bar Bushings & link)
Bonus: Rear Differential Bushings
or
superpro suspension
http://superpro.suspension.parts/pro...scion_frs_2013
FRONT AND REAR ENHANCEMENT BUSHING KIT Price: $519.32
Includes:
Front Lower Control Arm Bushings - Inner Positions - SPF3877K
Front Steering Rack and Pinion Bushings - SPF3914K
Rear Lower Control Arm Bushings - Inner Position - SPF3106K
Rear Upper Control Arm Bushings - Inner Position - SPF3100K
Rear Crossmember Inserts - SPF3907K
Rear Control Arm Toe Bushings - Inner - SPF3099K
Rear Trailing Arm Bushings - Front Position - SPF3817K
Rear Trailing Arm Bushings - Rear Position - SPF3098K
This is complete for $519 ?
or
power flex =
https://www.powerflex.co.uk/road-ser...RZ-2817/1.html
or
avo turboworld
http://www.avoturboworld.com/catalog...sbk0ojd2a16525
Or other ?
jefars is offline   Reply With Quote
Old 09-30-2016, 10:13 AM   #2
Tokay444
Eff urethane.
http://www.esmrace.com/category-s/166.htm
Whiteline bushing inserts vs. full bushing replacements mhiscott Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-15-2015 11:45 AM
Brz Front Lip (urethane) slyder Exterior Parts (Aero, Lighting, Etc.) 1 07-13-2014 11:59 PM
Is there an FRP/urethane brake duct out there? Blizzard Cosmetic Modification (Interior/Exterior/Lighting) 4 12-10-2013 10:31 AM
Pillowball or urethane for lca / uca diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-23-2013 11:40 AM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-09-2012 08:40 PM
