Old 09-29-2016, 03:54 PM   #1
ThornhillSubaruOwner
Drives: 2013 FRS
Auto vs Manual Transmission
I own an Automatic BRZ.
I know people who own Manual tranny cars can rev their engines and when they drive, their RPMs are typically higher. For example, the cruising RPM is around 4k is what I hear.
In comparison, Im usually cruising at around 2.5k-3k RPM.
My question is, is it bad for the Auto transmission if I keep my RPMS high at like 4k at all times while driving?
ThornhillSubaruOwner is offline   Reply With Quote
Old 09-29-2016, 04:00 PM   #2
bababooey
Drives: BRZ SWP Limited -6MT
over/under on 'shoulda bought a manual' responses @ 6
Old 09-29-2016, 04:03 PM   #3
gramicci101
Off Topic
You don't cruise at an rpm, you cruise at a speed. If the speed you're driving at happens to be at 4K RPM, then such is life. If you're cruising at 4K RPM in a lower gear when you could up shift and lower your RPM, then you're just wasting gas.
Old 09-29-2016, 04:04 PM   #4
c4lvinnn
Drives: Toyobaruion
No, your car will blow up
c4lvinnn is offline   Reply With Quote
Old 09-29-2016, 04:14 PM   #5
FX86
i keep my rpm at 4k in 4th gear all the time for a long time just in case i need to downshift to third for that break necking torque when i need to overtake another vehicle and make a lot of noise
Old 09-29-2016, 04:14 PM   #6
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I'd say that you actually do both. for any given speed, you pick a gear that puts you in an rpm range that matches your intentions. if you're 'cruising', which to me, means that you're maintaining that speed without much variation, then 4k sounds high. i'll leave it at 4k if i anticipate wanting to accelerate. otherwise i'd just select the gear so i'm around 2.5k to 3k. lower and it bogs the engine.
OP - your cruising rpm range sounds right to me. waste gas on accelerating, not cruising.
shiumai is offline   Reply With Quote
Old 09-29-2016, 04:16 PM   #7
c4lvinnn
Drives: Toyobaruion
i saw your name when you replied and I was like "I hope his avatar is of shuimai"
Was not disappointed.
Old 09-29-2016, 04:19 PM   #8
Icecreamtruk
Drives: Track preped NA FRS
Pull it thru that torque valley baby!
Old 09-29-2016, 04:24 PM   #9
Teseo
Drives: frs
MT. > Auto
Old 09-29-2016, 04:51 PM   #10
Drives: 2013 FRS
Is it bad for the transmission or engine though?
Old 09-29-2016, 05:57 PM   #11
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Not if you don't mind overheating your headlight fluid which is situated right next to the transmission.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
Old 09-29-2016, 05:59 PM   #12
Leonardo
Country Boy 4 Life
Leonardo's Avatar
AT and MT have their place. Just as AWD and RWD have theirs. You can not drive two cars at the same time. Some bought a Silver car, me, and others have bought blue or even now yellow! Would I buy a Yellow car, no. But does that make silver "better"? No not for a Series 1.0 or 2.0 buyer. But, for me yes. Just as MT is "better" for those that love it!
So Enjoy your car! Shift it at redline, or at 2000 rpm, whatever!
Old 09-29-2016, 05:59 PM   #13
humfrz
No.
humfrz
Old 09-29-2016, 06:24 PM   #14
strat61caster
strat61caster's Avatar
MT, never spend any time at 4k rpm.
The only reason to do that is to make noise.
ineedyourdiddly
Transmission swap: auto to manual... itdansharpe Engine, Exhaust, Transmission 39 02-12-2018 04:53 PM
Transmission Manual and Auto For Sale 2k miles sokol Transmission and Driveline 19 01-27-2016 03:49 AM
Keep Auto Transmission or Switch to Manual Stayreal Engine, Exhaust, Transmission 41 03-23-2014 10:02 AM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 11:33 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
