Old 09-24-2016, 03:26 PM   #1
DGM-BRZ
DGM-BRZ's Avatar
Drives: 2017 CWP STi
OFT Flickering
Im trying to connect my OFT to my computer but the screen seems to flicker and fails to connect. They OFT shouldn't have any damage as I keep it in the backseat of my car and never dropped it or anything.
Any thoughts?
Update:
It seems that the OFT or the chord is messed up, managed to connect it and get the job done.
I flashed the Stage 2 UEL 91 Oct tune onto my car and now the Engine light is on. When I flashed my stage 1 a while back, the same problem occurred but it disappeared the next day. Any reason for this?
Also, when I brake, there seems to be a little rocking movement that happens to my car.
DGM-BRZ is offline   Reply With Quote
Old 09-24-2016, 05:22 PM   #2
Teseo
Drives: frs
Can you read the codes?
The Following User Says Thank You to Teseo For This Useful Post:
DGM-BRZ (09-24-2016)
Old 09-24-2016, 06:48 PM   #3
DGM-BRZ
DGM-BRZ's Avatar
Not quite sure how to do that. What would I have to do to find the codes?
Old 09-24-2016, 08:33 PM   #4
DGM-BRZ
DGM-BRZ's Avatar
Update:
The CEL disappeared again... So I guess everything is okay.
Old 09-24-2016, 10:57 PM   #5
steve99
Any thoughts?
Update:
Likely the usb lead may be damaged, they are standard leads most computer shops will have one.
the cel code after flash is normal on auto trans cars its the auto trans computer whinging it cannot talk to engine ecu during flash think it P0700. just clear it
Old 09-24-2016, 11:05 PM   #6
DGM-BRZ
DGM-BRZ's Avatar
Thanks!
That's actually what happened last time too. It's gone now
Anyone notice flickering of their LED DRL?? BRZnut Issues | Warranty | Recalls / TSB 36 05-08-2020 10:08 PM
Car wont start, instrument Panel Flickering Subie_Nubie Issues | Warranty | Recalls / TSB 4 07-31-2016 04:56 PM
Interior Lights Flickering Skorov Electronics | Audio | NAV | Infotainment 14 05-01-2016 02:54 PM
Sidemarker LEDs flickering CreinCrein Cosmetic Modification (Interior/Exterior/Lighting) 5 05-12-2014 08:53 PM
HID BULB FLICKERING HELP!! ijuliusx Cosmetic Modification (Interior/Exterior/Lighting) 3 05-24-2013 03:18 AM
