Old 07-31-2016, 12:16 PM   #1
Subie_Nubie
Subie_Nubie's Avatar
Drives: 2013 Subaru BRZ Limted
Car wont start, instrument Panel Flickering
Hi All,
Looking for some insight into my issue. 2013 BRZ won't start, it's a keyless transmission. I noticed yesterday that the instrument panel is flickering and when depressing the clutch and pushing the ignition, the car makes a loud click but won't fire. Sometimes the dash will blink as well. Checked the voltage on the battery and seemed low, so we tried to jump it this morning and even with a steady charge it still won't turn over. Could it be a starter issue? The click is very audible and it just sounds like something isn't working. Stock besides a grimmspeed intake and Stage 1 OFT OTS tune. Don't know if that stage 1 flash is the culprit. Sucks because it doesnt seem to be letting me flash back to stock so i can take it to the dealer.
Any help is appreciated here.
Subie_Nubie is offline   Reply With Quote
Old 07-31-2016, 01:34 PM   #2
Subie_Nubie
Update: Also see the charging system warning light on and Low engineer oil pressure warning light. Not sure if both of these on indicate a specific problem or not. Manual says to contact dealer but they're closed today. :[
Old 07-31-2016, 01:35 PM   #3
Probably just a bad battery. Jumping seems to be hit and miss with these cars. The click is the starter solenoid engaging but not enough juice to spin the starter. Try swapping batteries before anything else.
Old 07-31-2016, 03:47 PM   #4
Subie_Nubie
Thanks guys, you happen to be right. Jumping it on the first car, an Infiniti, didn't seem to do the trick for some reason. Second time with a Toyota worked!
All good now, Pearl has a new pacemaker installed.
Old 07-31-2016, 04:56 PM   #5
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
For a 2013, it's probably about time for a new battery
Sent from my SGH-I747M using Tapatalk
daiheadjai is offline   Reply With Quote
Instrument Panel Fuse Box BRZfan Scion FR-S / Toyota 86 GT86 General Forum 6 07-10-2018 04:48 PM
Removing panel above instrument cluster inio DIY (Do-It-Yourself) Guides 3 08-09-2015 02:34 PM
Is the instrument panel slightly angled (or just me?) 1Cor10:23 Scion FR-S / Toyota 86 GT86 General Forum 13 07-30-2013 06:04 PM
Subaru 85 pcs LED Instrument Panel Gauge JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 0 05-16-2013 09:22 AM
How to remove small instrument panel? boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 4 03-02-2013 04:07 PM
