Old 09-20-2016, 06:00 PM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
LED better then HID?
this is actually brighter then my HIDs? should i get rid of my HIDs in low beam and LED in high beam (just for DRL) and replace with these??
http://www.ft86speedfactory.com/olm-...l#.V-GuQzuGVgo
lbroskee is offline   Reply With Quote
Old 09-20-2016, 06:03 PM   #2
Brayden_23
Drives: Asphalt 2015 FRS
As with all lights in the front of your car, they are only as effective as the housing they are in. If a housing is not built for an LED bulb, the usable light output will actually be lower than using the bulb that the housing was designed for.
*Insert all the stories of jackasses putting HID's in their reflector housings..*
Brayden_23 is offline   Reply With Quote
Old 09-20-2016, 06:05 PM   #3
lbroskee
lbroskee's Avatar
well i retrofitted to mini h1 projectors and ya i def understand the difference bc my HIDs were much better after that mod. but they also heat up and keep killing all my dam Halos
Old 09-20-2016, 06:06 PM   #4
ryoma
ryoma's Avatar
keep in mind that lumen rating is not the only spec that matters. you can have a high lumen bulb, but have poor projection which ultimately leads to poorer visibility compared to a lower lumens system but with proper design.
Old 09-20-2016, 06:09 PM   #5
lbroskee
lbroskee's Avatar
so running this, an HID system will be better i take it then?
https://www.theretrofitsource.com/bi...ni-h1-7-0.html
Old 09-20-2016, 06:12 PM   #6
ryoma
ryoma's Avatar
buy a 35w H1 HID kit from TRS. I recommend a bulb temp of 5000k for a nice white look.
Old 09-20-2016, 06:15 PM   #7
lbroskee
lbroskee's Avatar
thats what I'm running now actually and looks great, but the heat kills every set of halos i run within 7 months so was hoping i finally found a fix
Old 09-20-2016, 06:19 PM   #8
ryoma
ryoma's Avatar
the problem with LED bulbs compared to HID bulbs is that the light intensity coming from the bulb is different between LED and HID. once that light is reflected onto the bowl and into the projector, it will shift the hot spots of the headlights and will either make the projection worse or have minimal effect.
if you don't mind the possibility of decreased visibility and light, then using an LED bulb will be fine. it's not like using an LED bulb will blow up your car lol. it's up to you on how you want to set your priorities. also, maybe an LED bulb might not even be that much different from your HID bulb, who knows. you won't know for sure until you try it out.
Old 09-20-2016, 10:02 PM   #9
Brayden_23
If I understand correctly, the 2017's have LED headlights. I still don't know for certain if the main headlight is LED or if they are just referring to the DRL + turn signal, but if it's the low/high beam then you could possibly retrofit those housings onto your car if you really wanted LED headlights..
Old 09-20-2016, 11:41 PM   #10
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
They'll damn well try, though.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
Old 09-21-2016, 12:23 AM   #11
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
@Manic has http://www.modbargains.com/morimoto-...-scion-frs.htm in his low beams, and I'm running the same bulbs in my high beam (because I did a retrofit).
I was pretty impressed with his headlights...I know he's got an output photo somewhere on here.
Old 09-21-2016, 11:34 AM   #12
Manic
Is not fast.
Manic's Avatar
I've been pretty pleased. All LEDs are not made equal though. Granted, even my kit could have a brighter/more focused hot spot, but it's still miles better than the stock halogens. It all comes down to where the LEDs lie on the unit to appropriately match the halogen filament's position.
Old 09-21-2016, 11:56 AM   #13
lbroskee
lbroskee's Avatar
is that with stock projectors too?
Old 09-21-2016, 12:08 PM   #14
Manic
Is not fast.
Manic's Avatar
Yessir, projectors are unmodified. Now obviously there's the concern of blinding oncoming motorists as this was a common issue for people running HIDs in stock projectors, but I haven't noticed anything of the sort with the Morimoto 2Strokes.
Here's a photo of my cutoff. Granted, I'm much closer to the wall than I should be:
Now here's someone with HIDs in unmodified stock projectors taken from roughly the same distance as I was.
As you can see, the "squirrel-finder" pattern (the primary culprit of blinding oncoming motorists) is much tighter with my 2Strokes than the non-retrofitted HIDs.
If your HIDs currently aren't as bright as that OLM LED kit you linked, than they certainly aren't as bright as the 2Strokes.
