Old 09-19-2016, 10:54 PM   #1
sroby
Drives: 2015 Firestorm 08/05/15
Rear view mirror Detector mount
Looking for some ideas about frs detector mounts. I have the updated Home link mirror. It has the bigger mirror mount shaft. I picked up one of the rear view mirror mounts off the ebay. Its one that came recommended. It is not the escort brand. My problem is the mount is heavy along with my Redline 8500 hanging off the rear view mirror vibration is to much for me. Does anybody else using this type setup have a similar result as mine. Everything is tight, its just a blurry vision unless your on a silky smooth roadway. I don't want to trust the new style updated suction cup that came with it. I saw a nice setup for the c-6 and c-7 vets. Its a bracket that mounts off the sun visor clip from under the headliner. I am just looking for any alternative mounting other than the dash area. Thanks in advance Steve
sroby is offline   Reply With Quote
Old 09-20-2016, 12:32 AM   #2
ryoma
ryoma's Avatar
I use a Blendmount for my 9500ix. the detector does vibrate slightly while at idle, but that is because of my aftermarket engine mounts. it isn't that big of a deal and nothing comes loose.
Old 09-20-2016, 09:25 AM   #3
trd87t
Drives: Supra, BRZ
Blendmount here, expensive yes but no regrets.
1997 Toyota Supra TT 6MT - RR
2014 Subaru BRZ Limited 6MT - WRB
trd87t is offline   Reply With Quote
Old 09-20-2016, 09:00 PM   #4
sroby
Thanks so much I will check that one out. Thx Steve
Old 09-20-2016, 09:30 PM   #5
Gunman
Drives: 2019 Mazda Miata RF
Make sure the mirror mount screw is tight too. I've had that setscrew loosen up a bit, and things vibrate more.
I designed a mount, that functions similar to the Blendmount, without all the adjustments.
Gunman is offline   Reply With Quote
DIY-Replacing Rear View Mirror/Hardwire Radar Detector Lil Abner DIY (Do-It-Yourself) Guides 40 06-11-2020 02:48 PM
FS: OEM Rear View Mirror cammyT Interior Parts (Incl. Lighting) 2 11-22-2016 01:43 PM
FREE* Radar Detector Mirror Mount phloozy DIY (Do-It-Yourself) Guides 7 06-12-2016 04:05 PM
DIY JDM Rear View Mirror F1point4 DIY (Do-It-Yourself) Guides 29 12-23-2014 01:55 AM
OEM Rear View Mirror and OEM Side Mirror hanabie Cosmetic Modification (Interior/Exterior/Lighting) 2 03-28-2014 10:07 PM
