Old 09-12-2013, 06:20 PM   #1
phloozy
phloozy's Avatar
Drives: Scion FR-S
FREE* Radar Detector Mirror Mount
I just finished my DIY mirror mount and think it looks better than anything I have seen for sale (may not be as sturdy though). I did everything with items I had around the house.
**do this at your own risk, I am not an electrician and I do not know what permanent damage this can do to your radar detector**
Items needed:
Bike Reflector Mount
Something to fill the gap betweeen the bracket and the mirror. I wrapped mined in velcro zip ties.
A drill to make a mounting hole in your radar detector
A medium size screw, make sure to open your radar and test fit as to not hit the circuit board.
Step 1: Remove reflector from Bracket
Step 2: Wrap velcro zip ties around mirror base to give the bike mount a snug fit
Step 3: Open Radar Detector and make sure there is ample room to mount the screw
Step 4: Pre Drill a hole for your screw into the plastic casing
Step 5: Re assemble radar
Step 6: Attach the radar to the mount with your screw
Sorry it was dark in the garage :/
Lastly anyone with electrical knowledge, will that screw mess with the circuit or radar? should i cover it with electrical tape inside (its not touching anything)?
phloozy is offline   Reply With Quote
Old 09-12-2013, 06:26 PM   #2
userjack6880
userjack6880's Avatar
Drives: Raven FR-S MT
Depending on the clearance, the screw shouldn't effect anything. But, for good measure, I'd put something between it and the electronics. Electrical tape will work, but in a hot car, it can get kinda messy. It does have the advantage of not causing static when applying.
Great idea, however (at least in states where this is allowed).
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT
1978 Triumph Spitfire 1500
userjack6880 is offline   Reply With Quote
Old 09-12-2013, 06:29 PM   #3
phloozy
phloozy's Avatar
Drives: Scion FR-S
Ok I may do that, there is clearence room but it is only like 2 mm
Old 09-12-2013, 06:50 PM   #4
2013GTRNate
2013GTRNate's Avatar
Very good idea thank you for sharing.
2013 Nissan GT-R Premium
2014 Subaru BRZ Limited
2014 Forester XT Touring
My BRZ's thread: http://www.ft86club.com/forums/showthread.php?t=47467
2013GTRNate is offline   Reply With Quote
Old 09-12-2013, 07:24 PM   #5
Gunman
Drives: 2019 Mazda Miata RF
Bike reflector is a good idea. I'd try to velcro the detector to that base, so it can be removed, or adapt a larger base for more surface area.
I was lucky enough to have a former tool and die maker with his own machine shop for a father, so he machined a couple mounts for my V1. When the suction cup brackets broke, it screwed to the machined mount, I used a rapid prototype machine to make some new pieces for velcro. If I didn't have those sources, I'd be looking at bike reflector mounts!
Gunman is offline   Reply With Quote
Old 09-12-2013, 07:35 PM   #6
phloozy
phloozy's Avatar
Drives: Scion FR-S
I wish I had those resources. I just had spare time and a house full of junk
Old 09-12-2013, 07:46 PM   #7
Gunman
It's a great idea, regardless of the source. I was looking at mic mounts, and a lot of other things, before deciding to start from scratch, and a bike reflector wasn't one of them.:happy0180:
Old 06-12-2016, 04:05 PM   #8
Josh Ehlert
Drives:
This thread is old as hell but I'm bringing it back. This is the coolest shit I've seen in the last ten pages. I've discontinued use on my valentine1 because the suction cups do not like hot car and I constantly walk out to it dangling. I was just on the interstate today thinking of how to make a mirror mount. Little did I know the answer was lying in a bike reflector. Thank you for the post!
2013 UltraMarine Fr-S - Open flash tablet, Open flash UEL Header, Injen Intake, E85
Josh Ehlert is offline   Reply With Quote
DIY-Replacing Rear View Mirror/Hardwire Radar Detector Lil Abner DIY (Do-It-Yourself) Guides 40 06-11-2020 02:48 PM
DIY: Hardwiring your radar detector speedracer38 DIY (Do-It-Yourself) Guides 108 09-08-2019 10:06 PM
Radar Detector Recommendation? execoll Electronics | Audio | NAV | Infotainment 39 05-11-2019 03:59 PM
Win a Laser/Radar detector! raul Off-Topic Lounge [WARNING: NO POLITICS] 0 10-10-2012 01:57 PM
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 04:31 PM
