Old 09-08-2016, 11:53 PM   #1
phantasticity
Ricer
P0171, P219a after OFH2 install
I got those 2 codes p0172, p219a like 50 miles after installed openflash header v2, any ideas?
I'm on stg2 uel e85 btw.
phantasticity is offline   Reply With Quote
Old 09-09-2016, 01:03 PM   #2
jwvand02
Drives: 2013 SWP BRZ Limited
Did you use new gaskets?
Generally if you're getting this just from a header install it's either the header gaskets or the O2 sensor not being seated correctly.
jwvand02 is offline   Reply With Quote
Old 09-10-2016, 07:55 PM   #3
steve99
most likely you have exhaust leak
as previous guys said always use new gaskets
check the slip joint in header run some soapy water over it then start car when exhaust is cool.
check the 02 sensors in all the way and not leaking. run a thread tap through bungs in header if necessary
sensors installed in correct positions and plugged into correct coloured plugs.
you have high positive long term fuel trims , this is problem generally caused by exhaust leaks
Chech Engine Light On P219A P119E P0171 tonytduc Issues | Warranty | Recalls / TSB 4 09-21-2022 04:09 PM
NEW: OFH2, OFH3, v2.073 OTS maps and OFT350 E85 dyno results! Shiv@Openflash Engine, Exhaust, Transmission 67 12-10-2018 12:44 AM
CEL P219A? SpeedR Issues | Warranty | Recalls / TSB 38 05-24-2018 07:39 PM
P219A ENGINE CODE Albaro08 Issues | Warranty | Recalls / TSB 6 12-29-2015 05:15 PM
P219A TheseColorsDontRun Issues | Warranty | Recalls / TSB 3 12-09-2013 05:08 AM
