Old 09-05-2016, 07:21 PM   #1
acpstunts
Drives: 2013 FRS
Tire size question
So I have a set of 18x8.5 +32 fronts and 18x9.5 +38 rears.
My question is this setup ok:
225/40/18 F
245/35/18 R
My concern is the 35 sidewall in the rear going to throw anything off? The tires i was looking at does not offer a 245/40 but a 245/35 or 255/35. Or should i maybe just goto a 255/35?
My main concern is the smaller diameter rear. Is it going to throw anything off really? I know a smaller diameter should theoretically be better for performance (speed) but will it be ok for the handling characteristics of the car?
Thanks!
acpstunts is offline   Reply With Quote
Old 09-05-2016, 09:22 PM   #2
Synkopy
Dragon King of Jupiter
Drives: 2016 BRZ Hyperblue
I don't see a problem with running that setup.
Synkopy is offline   Reply With Quote
The Following User Says Thank You to Synkopy For This Useful Post:
acpstunts (09-05-2016)
Old 09-05-2016, 09:27 PM   #3
acpstunts
Drives: 2013 FRS
Ok awesome, i didnt think so, but i wasent sure with the 35 in the rear and 40 front if it would effect anything negatively.
Old 09-06-2016, 09:22 PM   #4
Synkopy
Well the aspect ratio is dependent on the section width. Think of it like a percentage. So the sidewall height of a 225/40 is 90mm while the sidewall height of a 245/35 is ~86mm. I doubt you'd notice much of a difference.
Old 09-07-2016, 09:42 AM   #5
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
I can't comment on the rear tire size, but for the front you're gonna get a little stretch (look) with rim width of 8.5. If you want more flush. Consider going to 235, altho it's harder to find.
jimmillion is offline   Reply With Quote
Old 09-07-2016, 10:43 AM   #6
gramicci101
Off Topic
The rear will be very stretched with a 245 on a 9.5. You could put a 245 on the front with no issues. Common tire pairings with those wheel sizes are 225/255, or 235/265.
Old 09-15-2016, 05:39 PM   #7
ModBargains.com
ModBargains.com's Avatar
Since the rear sidewall is lower, it will still have a similar ratio. Biggest difference will be the amount of stretch
ModBargains.com is offline   Reply With Quote
Old 09-16-2016, 12:48 PM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Biggest difference is in the OD.
MPSS tires differences
side wall = 90mm vs 86mm 4mm difference
strethch = 7.9 tread width to 9.0" on 8.5 and 9.5 wheels or 15.2mm vs 12.7mm less than 3mm difference
OD is 637.54mm vs 629.92mm Or 7.62mm difference
long story short they will work and look fine. I run 245/35 all around on 18x8 and 18x9.
http://www.tirerack.com/tires/tires....omCompare1=yes
http://www.discounttire.com/dtcs/infoTireMath.do
Old 09-16-2016, 01:32 PM   #9
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Staggered AND stretched... If just for looks and hard parking, fine though it aint my cup of tea (and no one asked so I'll shut up on that front now ). But if it were me and i wanted to drive this thing hard, I'd go wider on both front and back
Toyarzee is offline   Reply With Quote
Tire size question on 18 x 9.5 all around wheels. 8six_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-24-2015 10:09 PM
Tire Brand & Size Question ExxelDistributions Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-23-2014 05:03 PM
tire size question Frs32907 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-22-2014 12:04 AM
Tire size question..? Yamajee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 11-18-2013 05:21 PM
QUESTION: Rim & Tire Size at NJ & NY Figo NY / NJ / CT / PA 6 07-17-2013 02:21 PM
