Old 04-20-2014, 11:40 PM   #1
Frs32907
Drives: Asphalt grey, manual Fr-S
tire size question
i currently have
19x8.5 225/35-19 front
19x9.5 255/30 -19 rear
id like to beef up the rear tires so im not replacing them as often im on stock suspension possibly thinking coil overs within the next year. what would be my best option so i dont have and wheel sensor issues or rubbing issues for the back tires?
thanks for any advise
Frs32907 is offline   Reply With Quote
Old 04-21-2014, 12:57 AM   #2
primalT
primalT's Avatar
Drives: 2014 BRZ AT
I was actually wondering what the biggest wheel size you can fit is without any rubbing. Is it better to max at 18" instead of 19"?
primalT is offline   Reply With Quote
Old 04-21-2014, 02:17 AM   #3
samisons
Drives: 2013 Raven Fr-s, 2013 Versa Sedan
http://www.frsproject.com/tire_size.php
samisons is offline   Reply With Quote
Old 04-21-2014, 12:09 PM   #4
Frs32907
What size would the rears need to be if i wanted to run a xxx/35-19 back there?
Old 04-21-2014, 12:54 PM   #5
jshadeck
jshadeck's Avatar
Drives: 2013 Scion FR-S Whiteout 6MT
Originally Posted by Frs32907 View Post
i currently have
What do u mean? U are wearing out 255s quickly? How so?
Stock suspension, u wont have any rubbing issues
jshadeck is offline   Reply With Quote
Old 04-21-2014, 03:12 PM   #6
Frs32907
Yea my 255/30 have like 15k on them and gonna need replaced soon i i wanted to get a thicker rear tire so i dont go through them. As fast
Old 04-21-2014, 03:30 PM   #7
jshadeck
jshadeck's Avatar
Considered a better tread wear tire? Is ur alignment off? Stock HP? If ur wearing thru a 255 and think u wont wear through a wider option i assume ur wear is cause by wheelspin? If so you could just do less burnouts lol
Old 04-21-2014, 03:41 PM   #8
Frs32907
Not stock i think the issue is i need to go from a 30 to 35 but will i rub?
Old 04-22-2014, 01:04 AM   #9
jshadeck
jshadeck's Avatar
30/35 has no effect on tire wear. A 35 will make ur speedo/gearing off by 6% though.... W stock suspension i dont think ud rub. That tire size will also raise ur ride height 3/4"....
Tire size TofuAE86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-10-2014 01:03 AM
Tire size question..? Yamajee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 11-18-2013 06:21 PM
Tire Size and Ecutek Tune - Stupid question Pokeguyjai Software Tuning 5 10-04-2013 12:43 PM
QUESTION: Rim & Tire Size at NJ & NY Figo NY / NJ / CT / PA 6 07-17-2013 03:21 PM
Help with Tire Size Sivtec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-12-2013 01:40 AM
