Old 09-03-2016, 03:15 PM   #1
sickmint79
Drives: bmw
brake bias for cadillac caliper swap and other BBKs
wrote my first article on kinja comparing some of these kits and their bias changes with my best effort info:
http://sickmint79.kinja.com/ats-and-...390.1472560687
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
The Following 14 Users Say Thank You to sickmint79 For This Useful Post:
8R6 (09-07-2016), bhmax (09-06-2016), brandonblt2 (09-06-2016), cjd (09-04-2016), CSG Mike (09-03-2016), dem00n (09-04-2016), DustinS (09-06-2016), finch1750 (09-06-2016), Plastic Robot (09-12-2016), Racecomp Engineering (09-07-2016), Shark_Bait88 (09-06-2016), Teseo (09-07-2016), Toyarzee (09-06-2016), xkalelx (09-30-2016)
Old 09-03-2016, 09:47 PM   #2
Rememeber, the stock system intentionally has a "little extra" rear, intentionally, so that VSC can function.
I wish more people thought their decisions through like this.
wparsons (09-07-2016)
Old 09-03-2016, 10:53 PM   #3
n0thing
Drives: Subaru BRZ
so between the two wilwood options (front only, no rear), 4 piston is better?
n0thing is offline   Reply With Quote
Old 09-04-2016, 12:16 AM   #4
sickmint79
Drives: bmw
a buddy sent me this page after he saw the article: http://www.ft86club.com/forums/showthread.php?t=32594
wilwood had this to say: http://www.ft86club.com/forums/showp...6&postcount=18
although i don't find that comment very satisfactory.
per http://forums.nasioc.com/forums/show....php?t=1265631
the BRZ front rotors are 294x24 or 295x25.5
per http://www.ft86speedfactory.com/wilw...g#.V8uadPkrKUn
the 4R WRX rotors appear to be 305x20.5. i will let someone like CSG Mike comment on that, as others noted that seems rather thin. so i suppose there is a real question of how much improvement this kit actually gives you in thermal capacity, for the BRZ or WRX. (certainly more for us being 400 lbs lighter though.)
OP initial track impressions -
http://www.ft86club.com/forums/showp...0&postcount=71
http://www.ft86club.com/forums/showp...8&postcount=72
it would be cool to have some track temps.
some later impressions -
http://www.ft86club.com/forums/showp...9&postcount=76
those are simply not speeds i am running locally.
he appeared to eventually go to the 6 pot with a larger WRX rotor with OEM 86 still in the rear. i didn't see anything about a prop valve so it would seem this would have shifted bias forward a lot.
http://www.ft86club.com/forums/showthread.php?t=63636
Old 09-04-2016, 01:41 AM   #5
ryoma
ryoma's Avatar
I would like to mention that RR Racing also has a 6 piston Wilwood BBK (stage 1 & 2) which they claim to have tested and refined for proper brake bias on our platform. they're reasonably priced as well for $1000 a set. they do state to run more aggressive pads in the rear though if you're only running the front BBK. it seems to be a good option for the price to performance ratio if you're in the BBK market. however, for the majority of us, just upgraded pads and fluid will do the trick unless you want that bling factor lol.
The Following 2 Users Say Thank You to ryoma For This Useful Post:
sickmint79 (09-04-2016), TofuJoe (09-18-2016)
Old 09-04-2016, 06:39 AM   #6
DarkSunrise
DarkSunrise's Avatar
I've got the RR Racing stage 2 BBK with BP20 pads. When using PMU HC+800 pads in the rear, there seemed to be a lot of front bias. I could hear/feel the front tires lock up early in braking zones. Switching the rears to Carbotech XP10 pads seems to have returned the brake bias to normal. Also appears to have taken a significant load off the front brakes overall (less wear, smell, etc.) I definitely think the kit works better with a more aggressive pad in the rear.
That said, theoretically... I wonder if you want brake bias to be pushed slightly forward on sticky track tires. Under hard braking there should be greater weight transfer to the front (relative to a stock tire for example).
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
Old 09-04-2016, 12:16 PM   #7
sickmint79
Drives: bmw
i see lots of option at RR
http://www.rr-racing.com/Front-Big-B...gt86fbk001.htm
although i don't see anything about caliper piston sizing. it would be cool to add them if i can collect the info.
Old 09-04-2016, 05:40 PM   #8
sickmint79
Drives: bmw
chat with them directly. updated! a lot of really nice options from them!
Old 09-06-2016, 11:19 AM   #9
bhmax
Drives: 13 BRZ, 17 Focus RS
Great article. Glad more people are thinking about bias. When I did the calculation for stock a while back I got 65/35 assuming equal friction pads front and rear. I put on Raybestos ST45 front ST47 rear early this year which should have put bias closer to 60/40. I've been very happy with them. Only 2 track days at Barber and 2 AXs so far, but I have lots of confidence with the brakes. I haven't felt anything that makes me think I went too far rearward with the bias. One reason I did this was lots of people talking about the front brakes overheating. No hint of overheating and changing pedal feel at the track days at an intermediate pace. Hope to do a track night at AMP later this month. The brakes feel great on drives in the mountains. There's great modulation. I don't seem to have any problem getting just the amount of force I want when carrying the brakes into a corner. When simulating a panic stop, the fronts still get ABS activation with no hint that the rears are. I may have felt a hint of tail wag a couple different times when on the brakes in a slight turn on a road that had some loose sand/gravel. I had read of guys getting great pad life from Raybestos ST43 pads. Hoping that these are the same, because they aren't cheap. I'd get them again in a heartbeat though. I'm actually interested in trying out the cheaper Wilwood WRX 4 pots for the weight savings. I bet they'd work well for me with proper pads front and rear.
bhmax is offline   Reply With Quote
Old 09-06-2016, 11:55 AM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
does anyone actually have the piston size from the RR kit or is it still just taking their word for it?
Old 09-07-2016, 01:35 AM   #11
Bobster
Drives: GT86 GTS
I hear the WRX 4 pots move the BIAS to the rear as wheel, does that make them a better option?
Bobster is offline   Reply With Quote
Old 09-07-2016, 02:28 AM   #12
bhmax
When I checked into it (Wilwood WRX 4 pot kit) a few months ago I calculated that it moved the bias forward about 2%.
Last edited by bhmax; 09-07-2016 at 02:54 PM. Reason: Was referring to Wilwood kit, not OEM.
Old 09-07-2016, 04:12 AM   #13
Bobster
Drives: GT86 GTS
Originally Posted by bhmax View Post
When I checked into it a few months ago I calculated that it moved the bias forward about 2%.
Thanks
Sounds like it would be ok if you balance the pads a little. My other option was STi front's only. I think the stock rears are quite capable.
Old 09-07-2016, 08:18 AM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
RR IS reasonably priced. And their bias seems no that bad off as some of retrofits. BUT - if even vendor says that for proper use one needs to use different pads front-rear, i translate it "we didn't care about getting right bias, so use this hack to workaround" putting big red sign against considering them. I get if such hack is used for retrofits, i get it if used for non-standard aero / staggered wheel & tire setup .. but NOT if for standard set marketed for most cars, without clearly stating if it's for some specific setups.
The Following 5 Users Say Thank You to churchx For This Useful Post:
civicdrivr (09-07-2016), CSG Mike (09-07-2016), JRitt (09-08-2016), Racecomp Engineering (09-07-2016), wparsons (09-07-2016)
$600 Brake retrofit, Cadillac ATS brembos, STI rotors. etc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 135 12-24-2021 10:19 PM
Stoptech S/S brake lines: same between stock caliper vs big brake kit? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-10-2016 07:14 PM
Brake Bias & Proportioning - Shop Car Update Carolina Dyno Tracking / Autocross / HPDE / Drifting 10 11-07-2015 02:52 PM
Brake bias calculations for BBK Fizz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 09-08-2015 01:50 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
